ABS
Old Jan 12, 2007 | 08:25 PM
PeteS2RST's Avatar
PeteS2RST
Default ABS
Decided to remove the abs while i've got the engine out as its more accessible. But have a few questions.
Is it just a case of binning the modulators and related brake lines and remaking the lines directly from the master cylinder to the t pieces on either wing or do i need to remove the load compensators on the rear arm and use a fixed rate compensator on the O/S front wing like non-ABS escorts??
Any info would be great
Pete
Old Jan 12, 2007 | 08:52 PM
AndyRST's Avatar
AndyRST
Default Re: ABS
Pete, my RST was done that way you described above and worked perfectly. I didnt have any load compensators, just a straight copper brake pipe from the master cylinder to the front brakes. So yes i would do it that way
Old Jan 12, 2007 | 09:20 PM
PeteS2RST's Avatar
PeteS2RST
Default Re: ABS
what brakes were you running ?
Old Jan 12, 2007 | 09:30 PM
AndyRST's Avatar
AndyRST
Front: std sized RST Tarox groved and drilled, Ferodo DS2500 pads
Rear: Mintex Rear shoes and std drums, very well adjusted
Fluid : Autopart Dot 5.1
Hoses : Goodridge Braided
ABS removed, rear load compansators kept
No problems at all on track days, DEFO no fade from the fluid and IMO worked as well as a Set of "large" AP's and rear disc conversion on a well known RST
Old Jan 12, 2007 | 09:39 PM
PeteS2RST's Avatar
PeteS2RST
I know what i'm doing this weekend now
Cheers for the help
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
