Vectorised image...
Old Jan 12, 2007 | 04:10 PM
Muska's Avatar
Muska
Default Vectorised image...
can anyone on here help me in making a logo i have into a vectorised image please? Its for an engraver, and although i've found out what one is i don't know how to go about making my image into one! Would autocad be suitable?
Cheers,
Matt.
Old Jan 12, 2007 | 04:14 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
I think photoshop or paintshop pro would be suitable
Old Jan 12, 2007 | 04:15 PM
AndyBrew's Avatar
AndyBrew
what have you created the logo in?
Old Jan 12, 2007 | 04:21 PM
Muska's Avatar
Muska
i just have it as a picture at the moment. If paintshop is suitable then it should be all good.
Many thanks,
Matt.
Old Jan 12, 2007 | 04:52 PM
AndyBrew's Avatar
AndyBrew
you will need to get the logo re-illustrated by somebody depending on its complexity etc. wil either be quick/cheap job or long/expensive one
Old Jan 12, 2007 | 05:03 PM
cozmeister's Avatar
cozmeister
More boost Igor!
True
A vector image is a description of lines, angles and shapes, and where they are on the page. This allows them to be up and downscaled without any loss in image quality.
A bitmap image is literally that, a map of the pixels that make the image.
You can save a bitmap image in a vector image format, but when it's resized, you'll lose quality because the bitmap doesn't contain size information, like a vector drawing does.
A bitmap just says "there's a red dot here, a blue dot there, and a green dot there". A vector drawing says "there's a red circle here, it's diameter is x. There's a green square there, it's height and length are x and y." Basically, when you have dimensions to work with, you can resize anything to scale - when you don't have those dimensions, you'd make a best guess.
bassboy
Music & Car Audio Chat
Nov 9, 2010 08:31 PM
