T34 roller bearing article
Old Jan 12, 2007 | 12:38 PM
Rick's Avatar
Rick
Default T34 roller bearing article
can someone send me a copy/post it? Missed the mag.
Old Jan 12, 2007 | 01:53 PM
SafeChav's Avatar
SafeChav
And me
Old Jan 12, 2007 | 04:09 PM
addiction's Avatar
addiction
buy a back issue then
Old Jan 12, 2007 | 04:13 PM
grsford's Avatar
grsford
Rick
SafeChav
i will but i cant do it until about half 8 if thats ok?
Old Jan 12, 2007 | 05:30 PM
M K's Avatar
M K
ordering 1 of these turbo's in a slightly different spec next week for mine
SafeChav's Avatar
SafeChav
WHATTTTTTTTTTTTTT
Half eight
That will be excellent
Old Jan 12, 2007 | 05:38 PM
grsford's Avatar
grsford
the mags at the girlfriends
Old Jan 12, 2007 | 05:42 PM
grsford's Avatar
grsford
M K cant wait to hear how you get on with the new turbo im sure it will be very
Old Jan 12, 2007 | 08:31 PM
Rick's Avatar
Rick
The worst thing about GT turbo's, is thast they are mainly roller bearing core... So a Roller T34 is taking thw worst bits out of both series :S
Old Jan 13, 2007 | 02:11 AM
M K's Avatar
M K
well the performance is better than that of a standard t34 so it sounds good to me
Old Jan 13, 2007 | 08:53 AM
Fiecos Dan's Avatar
Fiecos Dan
i would bother with the artical, because it has clear flows in the test.
i'm not saying the turbo tested isn't better, just not as good as its was said to be.
i know as i had a similar turbo they tested, on a similar engine spec,
The power and torque is about correct, but not the way both turbo's are said to come in.
have a look here.
https://passionford.com/forum/viewto...asc&highlight=
Old Jan 13, 2007 | 12:08 PM
M K's Avatar
M K
il see how mine differs from standard t34 at the berks rolling road day
Old Jan 13, 2007 | 01:04 PM
SafeChav's Avatar
SafeChav
grsford top bloke
Only just got in so i haven't read it yet but thats greatlly appreciated
Old Jan 13, 2007 | 01:34 PM
Fiecos Dan's Avatar
Fiecos Dan
Please do.
have you done a RR power run on a DD RR on your T34?
Also
have you boost/rpm checked your T34 @ every 100 rpm, under full load in the car?
and on the same actuator, boost controll, and same full spec and same weather conditions, but just the turbo changed, do the same on the new turbo.
Old Jan 13, 2007 | 02:48 PM
Rick's Avatar
Rick
just read the article. It's no T34! It uses GT wheels.
Test is bobbins though, no power run as such, just loading it up as much as possible.
MK - be really nice to see how it goes on ur car.
89barto89
Oct 4, 2015 06:59 PM
fordrallycar
Sep 30, 2015 07:57 PM
20/20 vision
Sep 28, 2015 03:03 PM
