Temperature Gauge Randomness
Old Jan 11, 2007 | 07:46 PM
Arfur's Avatar
Arfur
Default Temperature Gauge Randomness
The temp gauge on the Saph has started giving strange readings - fine when sitting in traffic, as soon as you start moving it goes down and down the faster you go until the needle's on the bottom.
Any ideas? Presumably there's a voltage regulator attached to it - could this be breaking down?
Cheers,
Si
Old Jan 11, 2007 | 10:57 PM
Smit's Avatar
Smit
The 60ft Launch King
Tempurature gauge on the dash works off a stub unit which sits near the big ECU temp sensor on the head......
Might be worth having a new one as they are about 10quid. Smit.
Old Jan 11, 2007 | 11:09 PM
PROMETHEUS's Avatar
PROMETHEUS
does the fuel level move with rpm too? if yes its the regulator on the back off the clocks, it blows easily during welding!!!, the tempsensor usually fooks up after a boil up!
Old Jan 12, 2007 | 07:39 AM
Sticky.'s Avatar
Sticky.
Sounds like the temp sensor on the side of the head is fooked Simon.
Old Jan 12, 2007 | 09:09 AM
foreigneRS's Avatar
foreigneRS
Testing the future
what does the ecu temp sender do?
you can get this problem if coolant is low, or there is an air trap around the sensor. not enough flow from water pump at idle, but is during driving.
also, stuck open thermostat at this time of year will have the same effect
Old Jan 13, 2007 | 10:28 PM
AndyPen's Avatar
AndyPen
Default temp gauge
mine went haywire like that - kept dropping right down once the motor was warm - I simply cleaned the sender connection (bit fidley) and it worked great for a while... didn't drive it for a while and had to redo it to make it work again... so got a new sensor sitting here ready to go in.
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
