bailey tanks/ swirl pot
Old Jan 10, 2007 | 09:18 PM
LukeT's Avatar
LukeT
Default bailey tanks/ swirl pot
hi chaps am gonna get some bailey tanks for my 2wd sapp next month and wondering what all this swirl pot buisness is about sorry am quite new to this cosworth stuff and still learning
Old Jan 11, 2007 | 07:54 AM
rscossie86's Avatar
rscossie86
AUSTRIA
I hope i´ll manage to explain that with my bad english as i´m not a native speaker but i´ll try...
A swirl pot is mounted to get air bubbles out of your cooling system. When the coolant passes hot spots of the engine, it can partly start boiling and small air or better steam bubbles appear. This will cause your cooling system not to work so efficiently.
If a swirl pot is mounted, those steam bubbles will exit the system there.
I hope i could help you with that explanation...
Old Jan 11, 2007 | 09:25 AM
dojj's Avatar
dojj
Resident Wrestling Legend
if you are getting the header tank make sure you ask for the extra return to plumb the swirl pot into
Old Jan 11, 2007 | 04:08 PM
LukeT's Avatar
LukeT
excellent chaps thanks a lot
Old Jan 12, 2007 | 03:29 PM
Daveesaunders's Avatar
Daveesaunders
I've got the bailey set up on mine and it looks really good. As above the water enters the potas it exits it swirls round inside allowing air to escape through the top to the header.
Old Jan 15, 2007 | 04:28 PM
Mike at Corby Motorsport's Avatar
EDITED BY WEBTEAM
Old Jan 15, 2007 | 09:44 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Reads ok mate, well done
Steve.
Old Jan 17, 2007 | 11:26 PM
rscossie86's Avatar
rscossie86
AUSTRIA
Thanks! Glad to hear that...
I´ll continue training - I always wanted to buy a house in GB sometime
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
