Cam seals STILL leaking!!!!!
Old Jan 10, 2007 | 04:35 PM
LukeT's Avatar
LukeT
Default Cam seals STILL leaking!!!!!
Just had my 2wd sapp repaired and got it home only to find camshaft oil seal leaking from same place as before ...
Is this a common problem?
Please help
Old Jan 10, 2007 | 08:31 PM
costina's Avatar
costina
Live long and prosper!!
NEVER had a seal leak but between the head and cam cap does this area requires sealer
Old Jan 10, 2007 | 09:05 PM
LukeT's Avatar
LukeT
thanks for the help pal but have found prob they must have forgot to retention the bolts after warming the engine as i just put half a turn on each bolt has not cured it so they will have to re do it. Ps lovely car!!!
Old Jan 10, 2007 | 09:39 PM
Csm's Avatar
Csm
They are common for leaking
Old Jan 11, 2007 | 07:48 AM
AlexD's Avatar
AlexD
Post Miester !
I always find a spot of Gasket Sealent Does the Job at each end
Al...
Old Jan 12, 2007 | 03:33 PM
Daveesaunders's Avatar
Daveesaunders
Mine did that after I rebuilt it, hadn't used any sealant so had to re do it Has solved the problem though it has developed a new leak that I haven't managed to trace yet
Old Jan 12, 2007 | 06:07 PM
cos47's Avatar
cos47
If it wont stop try changing the cam shaft O rings mate
Old Jan 13, 2007 | 07:02 PM
captiva's Avatar
captiva
There are 2 allen screws behind the cam wheels (one behind each) and they have a small O ring which fails. This might be a good place to look as it often gives the impression it is coming from somewhere else i.e cam seals. I believe the oil is under pressure as it is a main oil gallery. It was spraying on to the cam belt on mine and then going everywhere
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
