Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
mk5 escort
Old Jan 10, 2007 | 12:09 PM
sara's Avatar
sara
sara
Default mk5 escort
diesel got a knocking noise from the front passenger side got the front up in the air and
1. should the anti roll bar slide easliy in its rubbers (bushes)
2. how much movement in the bottom arms should there be
any help would be muh appreciated
thanks in advance
Old Jan 10, 2007 | 04:08 PM
slickescort1981's Avatar
slickescort1981
Hiya. the bottom arms shouldnt really have much movement but if the rubber bushes look really perished or peelin away around the edges it could be worth changing em. if the arms are pretty bad then u may get the steering wheel snatching as u hit bumps. and the anti roll bar should have no movement whatsoever in the bushes. thats more than likely ur knocking noise as happened to mine recently, only couple of quid for the bushes anyway.
Old Jan 10, 2007 | 10:19 PM
sara's Avatar
sara
sara
thanks mate for that will change them in morn
il let u know how it goes
Old Jun 4, 2007 | 05:45 PM
phill295's Avatar
phill295
also check for movment in the anti roll bar drop links as this can cause a knocking noise
rex647
Mar 6, 2022 06:20 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
