Cam Belt Change
Hi everyone, a couple of questions you can hopefully help me with before i put my car back together (88 2wd Sapphire Cosworth.)
Started to change the Cam Belt on my car as am unsure when it was last done (i have receipts for everything, even new foam seat bolsters but none for a cam belt change!) and while trying to get the crankshaft pulley off i managed to break one of the four little lugs on the pulley off. It looks like there is some kind of sensor that maybe takes a measurement off these (crankshaft sensor?) so don't want to put it back on if my car is going to play up. Any ideas if i need to buy a new crankshaft pulley? In case my description is not clear on the back of the pulley there are four lugs at 90 degrees to each other and i have broken one of these off.
Also the box for the cam belt tells me to line the two arrows on the cam shaft pulleys up (left one at three o'clock and right one at 9 o'clock) and then line the cut outs on the crankshaft pulley up with the cast bracket on the block (which looks to be at about 12 o'Clock. Is this correct? as when i removed the belt this is not where the markings were. I had the right cam pulley at 9 O'clock but the left one was only at 2. Also the crankshaft pulley seemed to be at about 10 oclock and did not line up with the markings?
Thanks for your help.
Steve
Steve
Yes you need either to repair the pulley (ie weld the lug back on) or replace it - expect to pay around £40+ for a pulley.
There are plenty of threads on here about crank/cam/dizzy timing - try the search function (if it works).
Basically, the crank pulley has a V notch in it - DO NOT use this mark, but line up the trailing edge of the lug closest to the notch (crank rotates clockwise, so the left hand edge) with the marker on the front cover, the cam pulley pointers should point to each other, and the centre of the rotor arm with the small notch in the dizzy body directly beneath the rotor arm.
see here
https://passionford.com/forum/viewto...ghlight=timing
see here
this is how i time my engine up :-
bearing in mind mine is a 4x4 so crank may b different but hope this helps u anyway
both cam pulleys have arrows on they should face each other and line up straight with the cylinder head (the line where head meets cam cover)
it sonds to me that ur left camshaft was out of time.
crank is easy make sure the woodruff key is at 12 o clock(pointing straight up)
dissy drive there is an arrow on pulley and a half moon shapped casting behind it on the block line it up smack on half way in the semi circle
if unsure take off diss cap to check, rotary arm should be at number 1
turn engine over twice by hand after belt fitted if it doesnt lock up
turn the key
turn the key
Well make sure you use the correct mark on the crank pulley , as i didnt and currently need to take my engine apart
As some one said to me , turn over by hand to make sure everything seels ok , just incase
left pulley and right pulley the markings should face each other and the dizzy pulley should point towards the cap, the bottom pulley however, you need to line the pickup lug next to the marks on the pulley with the mark on the block. if your still unsure i'll post some pics up tomorrow when i take my engine out
as many people make this mistake and this is the result(they time it up like a pinto)
ouch
Why were you trying to take your crank pulley off mate? it doesnt need to come off, do as the boys have described above and you should be fine, and most importantly turn it over by hand first as you dont want what rab mc`s going through
Originally Posted by rabmc
Shit costinsa , thats what im expecting to see when my heads off
good luck
CrOwSoN15
Sep 14, 2015 11:33 AM
Adam Graham
Sep 6, 2015 06:04 AM
