XR3i Timing setting
Old Jan 6, 2007 | 09:31 AM
hutchyotb's Avatar
hutchyotb
Default XR3i Timing setting
has anyone done the timin on one before?? need to kno the timing marks, and the torq settings for the cams an head bolts???
Old Jan 6, 2007 | 11:07 AM
sexr3i's Avatar
sexr3i
isn't it
8v or 16?
Old Jan 6, 2007 | 11:17 AM
hutchyotb's Avatar
hutchyotb
16v
Old Jan 6, 2007 | 08:50 PM
sexr3i's Avatar
sexr3i
isn't it
there are 2 sets of nothches in the crank pulley, get the second set in line with a lug raised on the sump at about "5 o'clock". use a flat bar, 2 spanners, or buy a special tool in slots at the coilpack end of the cams to hold the cams at tdc, if the flat bar doesnt go in then try turning it over again so they are at tdc on the correct stroke (bottom end goes to tdc twice for a full combustion cycle).
headbolts, stg1 25nm, stg2 45nm, stg3 105degrees further rotation.
cam bearing cap bolts stg1 10nm, stg2 19nm.
Old Jan 7, 2007 | 03:32 PM
hutchyotb's Avatar
hutchyotb
cheers mate great help should get it done this week
FlashRS
Aug 30, 2015 08:07 PM
Steve Escos
Aug 24, 2015 07:56 AM
Dahl88
Aug 22, 2015 08:16 PM
marky_g
Aug 15, 2015 10:43 AM
Bloody-Fox
Aug 3, 2015 07:48 PM
