Compression Ratio
Old Jan 5, 2007 | 03:19 PM
richard_syko's Avatar
richard_syko
Default Compression Ratio
Currently rebuilding a 2 litre Zetec (E). Hoping to have my block decked, and my head skimmed (as its in a million bits) to up the compression ratio.
Can anybody advised on how much can be done, plan to put larger vavles and high lift cams in too.
Rich
Old Jan 5, 2007 | 05:42 PM
JesseT's Avatar
JesseT
What do you want the compression to be? Just remember that the squish distance is quite carefully designed to start with and removing material from the block can bring the pistons into contact with the head. Also keep in mind that different zetec head gaskets have very different thicknesses.
Old Jan 5, 2007 | 07:37 PM
richard_syko
11 or 12 to 1. Already got a Steel headgasket. I have checked head clearance and looks okay, just vavles Im worried about.
Imagine I`ll have to run it on premium then too
Prickly_buzz
Dec 7, 2017 09:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
