ST170 BRAKES
Old Jan 5, 2007 | 06:26 AM
Black_RS's Avatar
Black_RS
Default ST170 BRAKES
Just a few quick questions - what size are they? How much roughly should i pay for some calipers and what do i need to fit em to an S2RST?
Thanks.
Old Jan 5, 2007 | 07:10 AM
dojj's Avatar
dojj
Resident Wrestling Legend
300mm i think you can buy the whole set up for around £300 from ford new (or so the legend says)
Old Jan 5, 2007 | 08:21 AM
Dave Henshall's Avatar
Dave Henshall
what for new calipers, discs and pads,,,
that is cheap, might even try that route when i next need a set of front discs/pads...
Old Jan 5, 2007 | 08:31 AM
Black_RS's Avatar
Black_RS
Thanks fella. Does it fit the RS straight on or do i need brackets as i've seen some brackets on ebay - are these to fit standard calipers to ST discs?
Old Jan 5, 2007 | 08:53 AM
Black_RS's Avatar
Black_RS
Just spoken to my friendly local Ford parts dept and the calipers are £221.69 + VAT each new....
Ebay it is then....
Old Jan 5, 2007 | 08:57 AM
Dave Henshall
gonna say, that sounds more like it, not 300 for the whole front end
Old Jan 5, 2007 | 09:14 PM
dojj's Avatar
dojj
i read about it in one of the mags
i never did find them at that price though but it's a bolt on swap apparently as they st uses "conventional" hbs as opposed to the focus style "golf" hubs with built in calper carriers
Old Jan 5, 2007 | 10:06 PM
CliffRS4's Avatar
CliffRS4
I had this conversion on my rs turbo
It was an excellent conversion.
The discs are about £80 from Ford when I bought them.
I'm sure you can pick up a set of calipers from a breakers for not that much
You need 12 - 13mm spacers and the bolts are bigger that mount the calipers.
Sure you need to drill your hubs out to 12mm
I got mine from Gadget off of here but that was a very long time ago
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
