how much boost do you advise??
Old Jan 4, 2007 | 10:13 PM
Super5's Avatar
Super5
Default how much boost do you advise??
Hello,
How much boost do you advise me to run on my Saph??
It's got a standard t3,803's,rs500 spec. intercooler, 3inch scorpion, 3bar map sensor, and i think a 330 bhp chip.
My previous engine melted down the piston!!
Tanks!!!!
Old Jan 4, 2007 | 11:21 PM
Tarren's Avatar
Tarren
Default Re: how much boost do you advise??
Originally Posted by Super5
Hello,
Tanks!!!!
Hi Mate
I would say 18-20 psi anymore and your turbo will be on its limit
Old Jan 5, 2007 | 03:25 PM
wildheart's Avatar
wildheart
I'd say very little until its been set up properly.
Old Jan 5, 2007 | 04:15 PM
foreigneRS's Avatar
foreigneRS
Testing the future
less than you did before
you must be advised by whichever reputable company supplied/wrote the chip. if it's of unknown origin, i would not use it - a good one is not that expensive compared to a rebuild as i'm sure you well know
Old Jan 5, 2007 | 05:29 PM
DAN P's Avatar
DAN P
i ran 20 on that set up but only had a 2wd i/c
Old Jan 5, 2007 | 08:07 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
Hello,
Tanks!!!!
Hi Mate
Thats what i`d say, altho get it to a tuner too make sure, dont just drive about without getting a set-up
Old Jan 5, 2007 | 09:58 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
i ran a 26psi spike and 24psi held on a 2wd t3, it made 315bhp and 326lb/ft with a cracked exhaust housing wastegate seat!!
Old Jan 6, 2007 | 07:08 PM
Twellsie's Avatar
Twellsie
mine runs 1.7 bar, but on 403's and 4x4 intercooler
Old Jan 6, 2007 | 08:56 PM
rapidcossie's Avatar
rapidcossie
depends how you drive it..
if its being held flat out i wouldnt run as much as 20....
Old Jan 6, 2007 | 11:04 PM
rabmc's Avatar
rabmc
Id peak it at 18 and holding 1 bar to be safe , but thats just me
For all the difference a couple of psi would make , really this would be slot safer i would say
Old Jan 7, 2007 | 11:02 AM
melzieann's Avatar
melzieann
i would get a custom map on it, as said above £400 is cheaper than a re-build
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
