Cossie help needed please !!!!!!!
The saph has been parked up for 18 months and has now gone to the garage to get it back on the road
All the fluida and filters have been changed and from cold ot starts and funs perfect
BUT when it gets hot number 2 and 3 cylinders drop out, the garage has done a compression test and when the engine is cold all cylinders are as they should be but when hot number 2 and 3 are done to 20 psi. does anyone have any ideas for me to pass on
Originally Posted by Chip-3Door
When you say fine, do you mean that from cold they are 140psi+ and then when the engine gets warm they drop to 20psi?
Definately cylinder leakage test needed as well.
Then it looks like its off to a specialist by the sound of things for a professional diagnostic.
Well effectively the only things likely to cause low compression readings are basically:
Inlet valves not sealing
Exhaust valves not sealing
Head gasket blown
Pistons melted
Rings broken up (just worn out wont do that)
Block cracked
Head cracked
Given the fact its two adajacent cylinders and they are dropping to the same value, that makes it seem likely they are ending up connected together, so either head gasket or block or head.
Of the 3, the one that sounds most likely to be effected so much by heat is the block, but this really is guesswork without more info.
First thing I would do is a leakdown test, if you do it with the cams removed it will mean that you can see if the air from cylinder 2 is coming out the plug hole on cylinder 3 when you do it, this would confirm its one of those 3 options in terms of connecting them together with a crack or block gasket.
Head gasket blown
Pistons melted
Block cracked
Head cracked
Karl 3dr
102
Oct 14, 2016 08:17 PM
kosienutter
31
Aug 22, 2015 09:55 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
