Will an XR4x4 front cross member fit my 2wd sapphire
Old Jan 4, 2007 | 10:12 AM
davidnormanuk's Avatar
davidnormanuk
Default Will an XR4x4 front cross member fit my 2wd sapphire
I am getting the parts together to convert my 2wd to 4x4 providing I can source all the parts and was wondering if this will fit?
Dave
Old Jan 4, 2007 | 12:34 PM
IANS2RST's Avatar
IANS2RST
I have a spare 4x4 cos 1 u wuss
u will need
gearbox
gearbox mount
sump inc cross shaft
front prop
4x4 cos front diff ( xr4x4 1 is a diff ratio & will blow the box)
rear prop
engine mounts
front drive shafts
hubs
front brakes
front struts as these are diff to the 2wd
4x4 oil pick up pie to suit the sump
steering rack
would be easier to sell yours & buy a 4x4 as the floor will need modding as well
Old Jan 4, 2007 | 12:56 PM
davidnormanuk
Just pricing bits up at the minute to see if it will work out cheaper as genuine 4x4's seem to be doing good money. I have the time and space to do it and don't like doing things the easy way.
Old Jan 4, 2007 | 01:03 PM
IANS2RST's Avatar
IANS2RST
gearbox £200-£250
gearbox mount £10
sump inc cross shaft £40 max
front prop £50
4x4 cos front diff ( xr4x4 1 is a diff ratio & will blow the box) £50-70
rear prop £50
engine mounts £20-£130 best to fit uprated as the engine can pull the driveshafts out!
front drive shafts £100 - £150 pair
hubs £80 pair
front brakes £150
front struts as these are diff to the 2wd £50 -150 dep on spec
4x4 oil pick up pie to suit the sump £25
steering rack £30-50
over a grand there plus the labour
Old Jan 4, 2007 | 03:00 PM
jon@work's Avatar
jon@work
don't forget the starter motor and clutch release bearing, remote oil filter mount (?), and whatever else I've forgotten
Old Jan 4, 2007 | 03:08 PM
IANS2RST's Avatar
IANS2RST
and those
hows things m8? bet my 4x4 is back on the road before yours, even got a 2wd now as well
any progress on the engine?
Old Jan 4, 2007 | 03:39 PM
davidnormanuk
With the sounds of it it might work out better just to get a 4x4 to start with or swap both cars for a 4x4.
Old Jan 4, 2007 | 03:53 PM
foreigneRS's Avatar
foreigneRS
Testing the future
don't forget that as well as the transmission tunnel being different (space for transfer box, different mounting positions), there are also semi-circular nothes out of the chassis legs on a 4x4 for the driveshafts
jason_nike
Aug 18, 2019 10:53 AM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
track.focus'd
Aug 12, 2015 05:53 PM
lockie
Jul 31, 2015 10:03 PM
Old ford
Jul 31, 2015 06:50 AM
