anyone here actually work for ford?
Old Jan 4, 2007 | 08:45 AM
dojj's Avatar
dojj
Resident Wrestling Legend
Default anyone here actually work for ford?
and, if so, can you answer a question which has been floating baout for a while?
one of my new ford fitted tca's failed on my sierra a while back after only 4 months, the word from ford was that they didn't warranty this as i had fitted poly bushes to them
the garage that fitted them and i was chasing has since gone out of business (dagemnham motors uxbridge) so no reply there
so, is it true or did they fob me off because they were a bunch of coonts?
thank you
Old Jan 4, 2007 | 09:00 AM
DOO's Avatar
DOO
Cars got to be as it left the factory / standerd running parts for any warranty claim.
Even a simple mod changeing the wheels to bigger ones out it won`t be warranted .
plus you can get a warranty repair at any uk ford dealer don`t have to be the one you bought / got the parts fitted from.
Only way is to re fit back to the standerd bushes and anything else thats not standerd and ford will then replace the part inc labour under warranty.
Old Jan 4, 2007 | 09:07 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Very grey area with modifications, but in your case with it being so directly linked to the part that failed, sounds 100% positive you havent got a leg to stand on.
Old Jan 4, 2007 | 10:09 AM
Iain Mac's Avatar
Iain Mac
Don't think Ford or dealer would be liable to honour warranty on a modified part.
Like Doo says, if you can be bothered to put the orignial bushes back in, and they don't notice, another Ford dealer may make a claim to Ford on your behalf, but if the original claim was made and rejected Ford will have a record of it.
But modifications to one part of the car don't affect warranty on another.
E.g. - if you put different bushes in the TCAs and the CD player failed, the two are unconnected and the CD would still be cvered. It all gets a bit wriggly when they MIGHT be connected - e.g. you fit your bushes and the gearbox goes. The makers will argue that the new bushes alter an angle for the driveshafts, putting strain on the box or similar bollox, leaving you to prove that the mod DIDN'T contribute to the failure.
Old Jan 4, 2007 | 10:20 AM
Chip's Avatar
Chip
If they can suggest that a failure just *might* have been effected (even tenuously) by a modification they will refuse to payout.
So in the case of you changing the suspension around, which potentially sends extra vibration through the shell, and therefore prematurely wears out the delicate mechanism in the CD player.
And they would of course, be correct as far as a court was concerned, so you would likely get nowhere with your claim.
Old Jan 4, 2007 | 12:45 PM
dojj's Avatar
dojj
oh well,, at least i now know that when i go and send ford stuff back to keep the original stuff it came with back in again
although this may proove difficult seeing as i'd cut the inner bush out
Billy_RS
16
Oct 11, 2025 09:41 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
