cabriolet roofs
hi i have a mk4 cab with an electric roof which is more like a rag top i can get hold of a complete manual roof is there anyway i can get this to fit or will i have to use my old roofs frame work
cheers in advace im sure one off you lot out there know
cheers ben
cheers ben
your gonna need to remove the catches on the manual room that would sit under the piller,,, then you remove the ball joint things that the rams clip into and fit them to the manual roof frame and then you will have a electric roof on a cabrio
easy as that mate
easy as that mate
