Brake splash guards - MOT failure?
Old Jan 3, 2007 | 03:21 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Default Brake splash guards - MOT failure?
Just fitting cossie 4x4 rear discs and calipers to my XR4x4 but the bigger discs won't fit under the splash guard.
Is it an MOT failure to remove the guard?
Also, is it going to affect the discs much without the guard being present?
Cheers.
Old Jan 3, 2007 | 03:23 PM
righthooker's Avatar
righthooker
when i rebuilt my 3 door the splash gaurds/dust sheilds ,where no longer available .
If yo put larger discs on the rears they must be removed any how.
So the answer must be No ,as i have an MOT
Old Jan 3, 2007 | 04:20 PM
Olliexr4x4's Avatar
Olliexr4x4
If your old xr rear calipers are ok, do you fancy selling them?
Old Jan 3, 2007 | 04:41 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Righthooker - cheers. I guess its okay to leave them off then.
Ollie - Unfortunately the offside one was sticking badly which is one of the reasons I decided to upgrade so that one will be dropped in the skip. I'm not sure about the nearside one but it is probably pretty knackered as well. I can have a look at the nearside one for you if you want.
They are dead cheap on ebay or alternatively motor factors sell them quite cheap on an exchange basis is you already have a knackered set.
Old Jan 3, 2007 | 05:05 PM
DENNIS's Avatar
DENNIS
the splash guards are to prevent stones / water ect from getting on the disc, they are not part of the MOT test so if you can not get them, don't worry !!!
Old Jan 3, 2007 | 05:16 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Cheers I hoped that was the case.
Old Jan 3, 2007 | 07:43 PM
Olliexr4x4's Avatar
Olliexr4x4
No problem, I might just get some refurbed ones from http://www.brakeparts.co.uk/ just ordered some for the front, probably safer than messing about with second hand ones
Old Jan 3, 2007 | 07:50 PM
Jimboxr4x4's Avatar
Jimboxr4x4
I would have thought its better to get a known get set rather than risk some shonky old ones. Or alternatively do what i'm doing and change to cosworth rear hubs, discs and calipers. Doesn't seem that hard to do, although i did waste about 2 hours today pressing in the new wheels bearings.
Old Jan 3, 2007 | 08:00 PM
AlexF's Avatar
AlexF
How would they know they are missing
Alex
Old Jan 3, 2007 | 09:39 PM
Daveesaunders's Avatar
Daveesaunders
Mine have been removed for 4 years now and it passes the MOT every time
Old Jan 3, 2007 | 11:03 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Not had mine on the XR4i cossie turbo.
Steve.
Old Jan 4, 2007 | 10:25 AM
Iain Mac's Avatar
Iain Mac
My new XR4x4 rear splashshields fitted behind the Cosworth 4x4 rear discs with just a little bending. Cost was about £7-£8 each but that was a couple of years ago now.
Old Jan 4, 2007 | 10:47 AM
Fil's Avatar
Fil
ELASTIC BAND
mine were there , but not much of them due to all the rust, never had any mot problems
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
