what clutch for daily driver saff 4x4
Old Jan 3, 2007 | 08:18 AM
Cawood's Avatar
Cawood
Default what clutch for daily driver saff 4x4
the clutch is starting to slip on my saff 4x4
its running NMS gunship setup and is my every day car
what clutch should i go for?
cheers
Old Jan 3, 2007 | 10:02 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
An organic one, and if you dont mind spending a few quid while you are at it, then convert it to hydraulic, it will be one of those mods that you never regret doing IMHO.
No need for a paddle at that power level and they dont drive as nicely as an organic, as they have a tendancy to grab in traffic etc, although the 4wd system seems to iron it out a bit and they drive more nicely than a 2wd with the same clutch IME.
Of the paddle clutches available, if you do decide to go that route, 6 paddle is more civilised than 4 paddle.
Old Jan 4, 2007 | 10:13 AM
Cawood's Avatar
Cawood
cheers for the reply
whats involved in converting it to hydraulic? and what difference does that make
recommend any organic clutches whilst your at it also?
Old Jan 4, 2007 | 10:14 AM
KSA-Cossie's Avatar
KSA-Cossie
AP dave.
Old Jan 4, 2007 | 10:16 AM
Cawood's Avatar
Cawood
alrite kev, happy new year mate
hows your cossie going?
Old Jan 4, 2007 | 10:18 AM
KSA-Cossie's Avatar
KSA-Cossie
And you m8,cars going well,pics in the photo gallery m8.
Old Jan 4, 2007 | 10:46 AM
gingeRS's Avatar
gingeRS
i used my paddle as a daily driver, and other than the fact it is a little stiff, its fine
i would go for a hydraulic conversion while the box is off though, as its supposed to make it really nice and can help with the usually tricky changing mt75 box
Old Jan 4, 2007 | 10:50 AM
Chip's Avatar
Chip
Best bet for converting to hydraulic is to talk to Martin Hadland about it.
Ive converted other cars, but not a cossie, so dont know the ins and outs of it in the same detail as he does, but effectively you change the pedal for one with a master cylinder (possibly using one pikied from another car or a brake one if you are doing it on the cheap like ive done in the past) then you either fit a generic slave cylinder onto the standard mechanism or you swap it for the bits martin supplies to do the job more neatly.
yatta
May 21, 2016 10:31 PM
truffleshuffle
Sep 10, 2015 09:35 PM
Escortdriver1
Sep 6, 2015 10:12 AM
Adam Graham
Sep 6, 2015 06:04 AM
