what is your top speed in your stage 1 saff???
Old Jan 2, 2007 | 06:35 PM
RS LOZWORTH's Avatar
RS LOZWORTH
Default what is your top speed in your stage 1 saff???
Old Jan 2, 2007 | 07:29 PM
righthooker's Avatar
righthooker
should be no more than the diff will do , 158mph if i am correct
Old Jan 2, 2007 | 07:33 PM
bigad4x4's Avatar
bigad4x4
Surely the condition of the engine would hinder the top speed?
But on a sound engine would have thought 145- 158mph
Old Jan 2, 2007 | 08:28 PM
TIFF's Avatar
TIFF
Chasing Radders
Dont go on what the clocks say............They are always wrong after 110-120mph
I did a GENUINE GPS 154mph at Bruntingthorpe proving ground for Performance ford ...Was a Norris Motorsport Stage 1 on my 3DR
Old Jan 2, 2007 | 08:51 PM
RS LOZWORTH
i was just curious because mine pulls very well to 130-135mph then i havent really tried anymore just wonderd how much more was left really.....
Old Jan 2, 2007 | 09:09 PM
bigad4x4's Avatar
bigad4x4
Very true Tiff thats an impressive top speed
Can u rember what your speedo was reading?
Old Jan 2, 2007 | 10:01 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
My speedo was only 8mph out @ 162mph
Was showing 170mph speedo reading on a test day at Brunters with Fast Ford mag.
Mine is a stage 3
Steve.
Old Jan 2, 2007 | 10:04 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
My stage 1 cossie powered cortina done 146.7mph on a Performance Ford Test Day
Not bad for a brick
Steve.
Old Jan 2, 2007 | 11:50 PM
Sonic Boom's Avatar
Sonic Boom
When I first had my 3 Door it was Stage 1 and I got 155mph out of it down the A435 (according to the speedo)
Islands don't half come up quick when your going that speed
Rich
Old Jan 3, 2007 | 03:13 AM
llw's Avatar
llw
got 155 out of my stage 1, then the plug decided to melt
Old Jan 3, 2007 | 08:38 AM
AndyBrew's Avatar
AndyBrew
you wanna get the halfords temporary water pipe replaced before you attempt anything like this
Old Jan 3, 2007 | 09:06 AM
davecosworth's Avatar
davecosworth
IM BACK
sorry to jump on this thred but what would a 2wd cossie top speed be with greys t34 bd10 and std exhaust cam low compression pistons isk valve springs rs500 cooler smaco,s etc etc on a fresh rebuild all set up by steve scott at a1 rally sport my mate had it off the clock and hit the rev limiter in 5th
Old Jan 3, 2007 | 05:24 PM
RS LOZWORTH
indeed! dont think i want meltdown just yet
Old Jan 3, 2007 | 10:45 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Originally Posted by davecosworth
sorry to jump on this thred but what would a 2wd cossie top speed be with greys t34 bd10 and std exhaust cam low compression pistons isk valve springs rs500 cooler smaco,s etc etc on a fresh rebuild all set up by Steve scott at a1 rally sport my mate had it off the clock and hit the rev limiter in 5th
Depends on the Rev limit and tyre size.
Steve.
Old Jan 4, 2007 | 12:00 AM
rsvan's Avatar
rsvan
got mine up to 135mph (on the clocks) then bottled out
Old Jan 4, 2007 | 05:29 AM
MARCOSWORTH's Avatar
MARCOSWORTH
I did 260 km/h (161 mph) on the satnav
Old Jan 4, 2007 | 09:31 AM
joncos's Avatar
joncos
Steve.
7000rpm & Std cossie wheels 205 50 15
Old Jan 4, 2007 | 09:42 AM
lukeytheduke's Avatar
lukeytheduke
i did going downhill on a private track 158, no wines from diff, no dodgy noises from engine, and thats just a stage 1. I know it was that spped as i sell vehicle tracking and i used the GPS to identify an accurate top spped.
My speedo is pretty much spot on
Old Jan 4, 2007 | 10:02 AM
joncos's Avatar
joncos
Courtesy of Gearbox Mans web site.
An excellent Excel spreadsheet that works out your top speed.
This is the info given for my details.
It was my car that hit the Rev limiter in 5th.
Step 1: find out your tyre's rolling radius
(if you already know this value, skip this step and enter it below)
Enter these details:
Width (mm) 205mm
Profile (%) 50%
Rim size (inch) 15inches
Rolling radius (feet) 6.04feet
Step 2: gear ratios
(leave un-used gears blank)
1st 2.915 :1
2nd 1.932 :1
3rd 1.323 :1
4th 1 :1
5th 0.8 :1
6th :1
7th :1
Final: 3.64 :1
Step 3: shift RPM
shift point: 7250 RPM
rev drop speed MPH
1st to 2nd 2361 45
2nd to 3rd 2207 68
3rd to 4th 1709 100
4th to 5th 1400 132
5th top speed 165
Old Jan 4, 2007 | 10:46 AM
escort mk6's Avatar
escort mk6
i havent seen that site, but does it take weight and aerodynamics into account? as would they not have an effect on calculations?
Old Jan 4, 2007 | 11:25 AM
TIFF's Avatar
TIFF
Chasing Radders
Mine was running standard wheels and tyres at the time so it was all as Ford intended......
Just before i braked after hitting a GENUINE 154mph the speedo was reading between 165 and 170...... Thats how far out they are. Well mine was.
But i think you only have a good 1.4miles to get your readings at brunters before you have to hit the brakes......... So on a private motorway it would of been a little more i think
When the Speedo hit 150 it was doing 138mph on the GPS......Just so others can gauge what they were REALLY doing
Old Jan 4, 2007 | 12:15 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
This has no effect on the gearing, it just tells you what speed your car will do at a certain RPM.
Steve.
Old Jan 4, 2007 | 05:50 PM
cos47's Avatar
cos47
I got to 88mph and ended up in 1955
Old Jan 4, 2007 | 08:17 PM
radiant red's Avatar
radiant red
well mine is a 4x4 and is hardly stg 1 but i have seen it WHACK round to 170 when on test drive (lucky i had spare pants)
radiant red
i need some flux capacitaay shamone
Old Jan 4, 2007 | 08:27 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
I have to agree that some speedo`s are alot out but i think mines is as close as possible as when i was really revving mine racing a fireblade my speedo was saying about 158, and i didnt really want to hold it any longer as i felt it didnt have much more.
My car has 17`s 215/40, fresh rebuild with low comp pistons, little head work, nearly new tt stg2 t35, greens , 500 cooler, 20psi of boost
Surely If anything my speedo may be less
Old Jan 5, 2007 | 05:56 PM
Sonic Boom's Avatar
Sonic Boom
I always take mine out before heading down the Motorway
Rich
Old Jan 8, 2007 | 04:29 PM
kevin cozzer's Avatar
kevin cozzer
Default top speed
my stage 1 sapph read 163 mph down the a40 mate
3drRich
Sep 13, 2015 07:32 PM
matman
Sep 9, 2015 05:45 PM
Anutternutter
24
Aug 31, 2015 01:24 PM
JasonPD
21
Aug 20, 2015 07:36 PM
Bailes1992
Aug 16, 2015 07:14 PM
