arp stud kit
Old Jan 2, 2007 | 06:21 PM
cossie0_4's Avatar
cossie0_4
Default arp stud kit
im in the process of fitting a stud and nut kit on my cossie 2wd i have no instructions i noticed there is a allen key on the studs does this need to be torqued up if so how much and also what is the torque setting for the nuts aswell also there is no washers so do i not need any my car its an f reg so it as the later type bolts any help very much apreciated thanks and a happy new year to all cheers without places like this for help i would have scraped my car before now
Old Jan 6, 2007 | 11:38 PM
cossie0_4's Avatar
cossie0_4
any help appreciated
Old Jan 7, 2007 | 12:51 AM
jon@work's Avatar
jon@work
You do need the washers - cut the heads off the old stretch bolts and use those washers.
The allen key is to make fitting the studs easier if the head is already in place on the block. Tighten the studs into the block finger tight only. The rear 2 studs should be wound into the block so they sit at the same height as the front 8 studs - you'll find that the rear 2 studs don't bottom out like the others.
Tighten the nuts over a few stages to about 85 lbft if using the proper ARP moly lube. If using engine oil, I think the figure is about 130lbft.
Old Jan 7, 2007 | 08:40 AM
sailorbob's Avatar
sailorbob
If you are using the 190,000 psi, 12mm head stud kit the figures are;
80 ft lbs - ARP moly lubricant
120 ft lbs - 30 wt oil
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
little bram
Sep 27, 2015 07:45 AM
