Mk4 Fiesta - 2.0 Duratec Project - Updates 12/07
Right, As i've been a member on here for a while i thought it about time to show you what i'm up to...
this thread will be pieced together from other threads i've done, so please bare with me if it seems a bit "all at once"
i'm no-where near finished yet, so dont worry, you wont be missing out...
anyways here we go...
my car:
interior:
new engine:
aladdins cave (or shed maybe)
current spec...
early 1998 "zetec" model
Mechanical: 1.25 16v, Powerchip, Pipercross Induction kit, Motorcraft Plugs, Champion Triple Silicon Leads, Powerflow full custom cat-back system (4" rolled in), Puma 1.7 T/B.
Chassis: H&R adjustable Coilovers around -100mm, Brembo Four-Pot brakes with 305 x 28mm grooved and drilled discs, Zetec-s Rear beam, Focus 2.0 rear discs. Braided hoses. Widened by 15mm either side at the front and 20mm either side at the rear. Powerflex wishbone and rear beam bushes, uprated balljoints. Front upper, front lower and rear upper strut braces. Arches rolled and bumper mounts modded for more clearance.
Wheels: 16" OZ superlegerras in Metallic Black with 195/40 Pirelli P-Zero Nero's
Styling: Fiesta Mk4 RS Accessory Sideskirts, smoothed boot, colour coded roof strips. Black Meshed upper and lower grills, Ford RS accessory Front Splitter and Fog Surrounds, Mattig Sports Grill, Custom Mk5 Zetec-S Rear Bumper, smoked side repeaters, Tinted Headlights and Fogs, Philips blue vision Headlight bulbs, Debadged all-round. Mk5 fiesta 3rd 'high-level' brake light. Smoked Rear Lights. Pop-out rear windows fitted, and leccy fronts installed. Extended Bonnet and soon to be re-done bonnet vent.
Interior: Pug 206 Gearknob, ghia interior light. Blue LED dash conversion. Black Interior and Dash, Cobra Imola's, Momo Jet Steering wheel. First person to get the chrome dial surrounds
Rear seats removed, and floor added.
Security: Laserline 2:1 System with thatcham cat 1 anti-jack tilt sensors, McGard locking wheel nuts. extra siren.
my car:
interior:
new engine:
current spec...
this was the workshop about 3 weeks ago, just about insulated and pannelled... alos had the lights and sockets wired in too:
and this is it now, i finished about an hour ago
so time for me to get an engine stand, stripping back to the bare block and head (to work out what i need to keep and what i dont), and start sorting through and organising the parts i have...
as for throttle bodies or management, as i'm paying out for my insurance in a few days i'm back to square one, gonna keep the car running until i can afford to buy all the bits (hopefully in a couple of months with some luck) then i will set to getting the bad-boy in
in the mean time, there will be some light bodywork done, and attack some small patches of rust that are appearing (majority will be sorted sometime next year, as i plan to get a full de-dent and respray), and the engine bay/behind front bumper will be done whilst the engine is out
watch this space!
watch this space!
a small update:
engine stripped back as far as i want it to be...
this will new be cleaned and painted... block, head, and front cover will be silver, sump will be black
rocker cover has been primed as i want to see what it looks like in radiant red...
couple o bits come through from raceline...
EGR Blanking plate
Oil Filter Housing (to replace bulbous original item)
Inlet Manifold for Throttle Bodies
Throttle bodies being ordered hopefully in next few days :thumbsup:
EGR Blanking plate
right, on saturday i made a little progress...
Pumps and tensioners start to be bolted back on...
starter motor back on
Hole where the EGR valve used to be
another pic of the block
Where the original oil filter mount used to be
New Raceline Inlet Manifold Fitted (still need to get some proper bolts)
New Raceline Oil Filter Plate
Raceline EGR Blanking Plate fitted
some more compiled updates:
everything finally arrived (i hope)
my favourite bits:
lightweight alternator
Tensioner (from ford), modified to give more clearance (by cosworth)
lightweight water pump pulley... my one and only cosworth branded part, lol
hopefully this weeked should get it all bolted on and then i'm not far away from starting the conversion.
update...
alternator is on :thumbsup:
in the meantime, whilst at peewee's the other week, he kindly took some pics as the car had been back into the bodyshop to have the bonnet sorted (wasn't happy with the way it'd been done), and to have the paint on the wing and grill sorted (bad sprayer).
and i just like this pic
cheers peewee :thumbsup:
Well, no updates still, finding it hard to motivate myself when its so cold, but to keep things up to date, i have bought a few new parts..
these are thanks to Peewee :thumbsup:
Omex Series 600 ecu
Vibratrechnics engine mounts (hopefully i can use/mod for use)
Quaife ATB Diff
Also, these came through the post this morning:
330cc injectors (plus 1 spare)
and i didnt mention this, but a few months back i purchased:
this GRS alloy rad and fan (from a zetec turbo FRST) again, should fit with a little adjustment.
and fingers crossed, i think i've located a couple of other cages which i'm currently negotiating with the owners to sort a deal for one.
so anyway, thats the current update, this w/e after i've wrapped presents i'm gonna make a start on the gearbox with an aim to have it rebuilt by the end of my christmas holiday (2nd Jan)
RIght final update (26/12/06) - i'm dismantling the gearbox
I have also purchased a rollcage, and waiting on delivery
my favourite bits:
update...
Omex Series 600 ecu
Quaife ATB Diff
Nice project and you seem super organised too! I wanted to build a bench like that in my shed when i put it up but it started raining so i had to throw all the $hit back in quick - that was 18months ago.... doh!
Also, do i see a sneaky door build in this pic? ->
should be somewhere in the region of 180-200bhp when it goes in
once i've "finished" the car i.e. got the car resprayed etc then i'll consider building a full 'balls out' duratec to slot in
Originally Posted by mossymk4
i wanted peewees ones, but i couldnt raise the cash before ken did, what ones are you running on?
looks like you know what your doing mate, keep up the good work
