tune my car
Old Jan 2, 2007 | 02:53 PM
wuzie123's Avatar
wuzie123
Default tune my car
hi i have a 1.8 focus i need some more power out of it wht are ALL ny options to get the most power anything from like 2.0 or st170s whts the best cams to use? thanks doug
Old Jan 2, 2007 | 03:52 PM
zippy144's Avatar
zippy144
Hi
If you don't want to go down the turbo or supercharger route these are probaly your best options...
Good stainless exhaust ( Piper, Magnex etc not powerflow or similar)
Exhaust manifold- ST170 manifold and Cat is the easiest way
Piper fast road cams
Engine management- If you run cams i am told Bluefin won't work correctly, so a custom map or Omex is you have lots of cash to burn!!!!
Induction- I kept the standard airbox on my 2.0L and put a K&N element in and made a custom cold air feed using a Pipercross 75mm hose kit, i think this helps stop heat soak, as you would get from a standard cone filter..
Throttle bodies- Expensive- but gives good results and what a sound....
Regards
Tom aka Zippy
Old Jan 2, 2007 | 06:10 PM
AndyCanning's Avatar
AndyCanning
hey zippy, the air feed you made... i gather you have added a st170 snorkel etc..
from below and its helped a few focus's i know
Focus Automatic Air Deflector
ST170 Snorkel
http://www.fordpartsuk.com/Merchant2...egory_Code=FFU
hope that helps..
Old Jan 2, 2007 | 07:02 PM
zippy144's Avatar
zippy144
Hi
Nah, Pipercross sell a Cold Air Feed Kit which comes with 75mm ducting, and luvres.
I cut the bottom of the airbox so the bigger airfeed would have no restriction. I put the intake behind the front grill between the raditor and bumper, mainly so it wasn't too ovious it was there...
Regards
Tom aka Zippy
big_Rad
Sep 15, 2017 09:36 AM
Shows & Track Days
Aug 26, 2015 05:11 AM
Roosie
27
Aug 19, 2015 12:16 AM
Shows & Track Days
Aug 15, 2015 06:25 AM
