Help with water leak please??
Passionford Thread Killer
Hi, I have water comming out of where the exhaust manifold meets the turbo manifold
, and i don't know if it will be from a failed head gasket or a turbo leak. has anyone had this before, or can you help?
cheers.
Sorry 2wd saff coss
, and i don't know if it will be from a failed head gasket or a turbo leak. has anyone had this before, or can you help?cheers.
Sorry 2wd saff coss
Originally Posted by cos47
Any water marks on the block mate ?
does it only do it from cold? if so it'll just be condensation (leaves a white stain down the fannymold)
if it's head gasket there will be other symptoms;
water/oil mixing
losing water
poor running
water/oil mixing
losing water
poor running
No its started losing water
, and running abit shite.
Plus it is alot of water, to much for just condensation.
think I will have to do a block test, I just didn't know if it could be the turbo . Can they leak?
, and running abit shite.Plus it is alot of water, to much for just condensation.
Mark RS
Oct 12, 2015 06:01 AM
