saphy throttle pot
Old Jan 1, 2007 | 04:51 PM
need4speed00001's Avatar
need4speed00001
Default saphy throttle pot
Can anyone tell me what the setting is for a tps on a 4x4 sapphire and where do you measure it?
cheers, its only simple when you know!!!!
Old Jan 1, 2007 | 05:02 PM
jon@work's Avatar
jon@work
1) Ensure ignition is OFF.
2) Remove rear of ECU plug cover and insert plug back into ECU.
3) Turn ignition back on (do not start engine)
4) THROTTLE CLOSED:
4x4: Check for DC voltage less than 0.5V between pins 11 and 17.
5) THROTTLE FULLY OPEN:
4x4: Check for DC voltage greater than 4.5V between pins 11 and 17.
Old Jan 1, 2007 | 05:19 PM
need4speed00001
thanks for that jon,so if i have more than 0.5 on throttle closed,i can then lower it by slackening the tps itself and turning it untill i get 0.5?Nice one.The problem i've got is getting my exhaust emissions down,so i am checking all the settings first.Im running closed loop and i cannot get the emissions lower than 3.5% should be0.8%
Old Jan 1, 2007 | 09:21 PM
richm's Avatar
richm
at idle the voltage needs to be <0.35V - from experience between 0.25V and 0.3V is the best bet to get reliable idle position recognition.
Old Jan 1, 2007 | 10:05 PM
need4speed00001
thanks richm i'll check it and reset it, i know that it hasn't been set that accurately.
Old Jan 2, 2007 | 09:46 AM
paul brace's Avatar
paul brace
Default happy new year
happy new year mate
Old Jan 2, 2007 | 01:15 PM
need4speed00001
happy new year to you matey!!!!!
Old Jan 2, 2007 | 04:53 PM
need4speed00001
Thanks guys i set it to 0.28 and it has transformed the car.I had an annoying click from the amal valve everytime i touched the accelerator thats gone too.
cheers
mk3ste
Oct 17, 2021 10:09 AM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
IainRS1700T
Sep 25, 2015 06:44 AM
