cossie compression
Old Dec 31, 2006 | 02:35 PM
Basky's Avatar
Basky
Default cossie compression
just done a comp test
no1-140
no2-140
no3-140
no4-135
does this sound right (std comp)
Old Dec 31, 2006 | 02:41 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
I'm no engine expert, but that doesn't sound like much variation to me - whenever I've done comp tests it's been
140 140 140 0
Your results sound fine to me! I wish I had that much compression that's for sure.
Si
Old Dec 31, 2006 | 02:42 PM
St3V3_C's Avatar
St3V3_C
Yup. You are looking for even (ish) numbers on all 4.
You CAN'T tell if it's high/standard/low comp from a compression test.
St3V3_C's Avatar
St3V3_C
LOL @ SiB
Old Dec 31, 2006 | 02:51 PM
Basky's Avatar
Basky
[quote
You CAN'T tell if it's high/standard/low comp from a compression test.[/quote]
it is std comp.
@ si
must get it ready for combe this year
Old Dec 31, 2006 | 03:14 PM
biscuittin's Avatar
biscuittin
sounds good to me
i did mine the other week and they were all around the 140 mark
Old Dec 31, 2006 | 04:38 PM
scruffythefirst's Avatar
scruffythefirst
As long as thats warm, with the throttle wide open its fine. Try it again with before and after a squirt of oil down the bores, if it goes up a lot all the rings are evenly knackered
Old Dec 31, 2006 | 05:08 PM
scruffythefirst
oops repost
Old Dec 31, 2006 | 05:59 PM
Basky's Avatar
Basky
well its done 8 track days, and thought of freshening it up
don,t know now
that was warm not running temp
Old Dec 31, 2006 | 09:56 PM
Alan s1's Avatar
Alan s1
mine was 95 90 95 85 (or simlar) i think its whot you may cool a bit worn aslong as there with in 10% of each other its fine i was told
Comerdy Dan may rember me taking my cossie to jamies it turned out my miss fire was due to the cam belt being a tooth out and shit compression that was 2yrs ago only just removing it now (and it still runs just not great
Old Dec 31, 2006 | 10:15 PM
Alvyn's Avatar
Alvyn
Comerdy Dan may rember me taking my cossie to jamies it turned out [b]my miss fire was due to the cam belt being a tooth out and shit compression[/b] that was 2yrs ago only just removing it now (and it still runs just not great
Alan those figures are too low for any Cossie to be healthy and I'LL bet you the reason is that the valves have clipped the pistons and AREN'T fully seated in the head(you'll be able to see where the carbon's blown by) once you've taken the head off!
all the best to you and family for the new year
Old Dec 31, 2006 | 11:37 PM
Alan s1's Avatar
Alan s1
Alvyn yer some thing not right
The other thing is when it was done by a m8 it showed 110 ish with plugs in but i was also there when Jamie and dan ect did it and it was lower alot lower
still run and got abused for the 6 months i had it on the road and 18months later i have nearly got the new engine in
I'll be looking into whots up with myh old one when its out
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Fezman1
Oct 2, 2015 01:22 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
