inlet manifold with throttle bodies
does anyone know where or who could make me a inlet manifold adaptor plate to run bike throttle bodies on a 1.6 zetec engine, ive heard that boggs brothers do conversion/parts but carnt find any detailes about them, thanks
deffo bint he 1.6 and use a 2.0 or 1.8 at least
you can use part of the focus st170 inlet, this will bolt directly to the head and has 4 tubes that you simply join to the tb's with silicon hose
or you can make your own inlet like it did when i done mine, wasnt the pretiest but dont the job
is the st170 same as the 1.6ie will it just bolt up?, the engines going in a ka and i want to keep the weight down and there is very little space in them anyway, thanks for the info though!
1.6, 1.8 and 2.0 are the same size engines externally and have not got much difference in weight.
The 1.6 head is shit to say it nicely.
Putting trottle bodies will not help. The ports are like a ducks arse.
i thought the 1600 zetec engine was all aluminium therefor lighter than most engines, im not just putting some throttle bodies on its using omex managment with a piper cam set also some headwork along with piper exhaust and miltek manifold and decat, alot of people have seen good power from the 1.6 and are used in a few kit cars
1.6 is cast iron unless your on about a Zetec SE. Even with OMEX, and the 1600 Zetec heads still no good as it has tiny valves with a tiny combustion chamber to they cant be enlarged
sorry it is a zetec se-out of fiesta or foucus its also a phase 2 engine, thanks for your info, the kit that i am getting is from a company called shawspeed if you want to check there website and let me know what you think of there engine kits shawspeed.com im aware the the bhp will be less due to me using power stearing sapping some power, thanks
Johnny Knoxville
Sep 30, 2015 07:21 AM
caprixpack
Sep 25, 2015 07:53 PM
