EsCos Weight Distribution......
Old Dec 30, 2006 | 12:29 PM
KW-rscos's Avatar
KW-rscos
Default EsCos Weight Distribution......
as above anyone know the front/rear weight distribution of a standard motorsport model EsCos? and if anyone knew the side to side (if there is a difference) then that would be amazing.
Cheers in advance.
Old Dec 30, 2006 | 01:24 PM
KW-rscos's Avatar
KW-rscos
BTTT - Someone must know this!?
Old Dec 30, 2006 | 01:29 PM
mk2rstaff's Avatar
mk2rstaff
go on google and find the esc cos web page mate it will be on there
Old Dec 30, 2006 | 01:30 PM
KW-rscos's Avatar
KW-rscos
Cant find it anywhere, there used to be a cream coloured page that had all the info of the road car against the rally car, but can find it now!?
Old Dec 30, 2006 | 02:10 PM
mk2rstaff's Avatar
mk2rstaff
ok mate i will look in my manual
Old Dec 30, 2006 | 10:06 PM
KW-rscos's Avatar
KW-rscos
Any luck?????
Old Dec 30, 2006 | 11:21 PM
mk2rstaff's Avatar
mk2rstaff
no mate had a look but nothing of the sort in there, there is a site i found but its under construction at the mo
Old Dec 31, 2006 | 12:23 AM
KW-rscos's Avatar
KW-rscos
No worries, cheers for looking. looks like I will have to wait
Old Jan 2, 2007 | 03:03 PM
KW-rscos's Avatar
KW-rscos
Right, I have searched everywhere, all sorts of sites but I cant find it anywhere, someone must know!? please help!!!!
Old Jan 2, 2007 | 03:46 PM
kennyA's Avatar
kennyA
my standard ST Escort Cosworth with bolt in roll cage was 1350Kg. unfortunately I didn't get the corner weights.
The only other info I have is after removing seats, carpets etc, not much good if you have a road car. However here it is.
with me in the car, I'm 83Kg and 15ltr fuel in tank.
Front R 330kg.
Front L 370kg.
Rear R 249kg.
Rear L 260kg.
My car is LHD and the front doors were still steel, the doors weigh up to 40Kg the pair.
Old Jan 2, 2007 | 08:38 PM
KW-rscos's Avatar
KW-rscos
Front R 330kg.
Front L 370kg.
Rear R 249kg.
Rear L 260kg.
Nope that is spot on, as long as I have the other factors which you have stated, so cheers bud
Old Jan 2, 2007 | 08:42 PM
GARETH T's Avatar
GARETH T
i bet mike r will know tomorrow to the nearest gram
Old Jan 2, 2007 | 08:52 PM
KW-rscos's Avatar
KW-rscos
wowk
Mar 30, 2021 07:49 PM
gcfcos
59
Oct 6, 2015 05:04 PM
pabloXR
Sep 21, 2015 12:42 PM
gcfcos
Sep 11, 2015 06:03 PM
Mickeystewart
Sep 9, 2015 04:04 PM
