over boost
Old Dec 30, 2006 | 10:41 AM
rsjonesy's Avatar
rsjonesy
Default over boost
hi just got meself a new erst s2 and its overboosting its got a bleed valve but was just needing to know which way to turn it to turn the boost down. thanks for any help
Old Dec 30, 2006 | 10:45 AM
rssteve's Avatar
rssteve
can't you remove the valve all together so it runs standard boost then get it setup?
Old Dec 30, 2006 | 10:55 AM
rsjonesy's Avatar
rsjonesy
its got an uprated actuator and im not sure what the bloke b4 me has done with it if hes adjusted the boost with that duno if that make a differance.
Old Dec 30, 2006 | 11:07 AM
coswurv's Avatar
coswurv
I have a set of chipped ecu's if your interested so that way you can run more boost without it overboosting cheeRS.
Old Dec 30, 2006 | 11:16 AM
TIFF's Avatar
TIFF
Chasing Radders
Get it set-up properly or....................
Old Dec 30, 2006 | 11:38 AM
Dicko&Vacant's Avatar
Dicko&Vacant
take the bleed valve off but if not im sure to turn boost down you need to compress the spring thats all i know
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
