XR2 MkII & S2 RS Turbo Gearbox Compatibility?
Old Dec 29, 2006 | 10:11 PM
TwoCossieBob's Avatar
TwoCossieBob
Default XR2 MkII & S2 RS Turbo Gearbox Compatibility?
Hi Chaps
Will an S2 RS Turbo gearbox go straight into my XR2 MKII race car? I want to make use fo the lsd in the Turbo box. I know the gearbox mates to the cvh engine and goes in the MKII shell all ok but what about the driveshafts? Can I just use the original XR2 ones as it would be much easier if I could? Are the splines the same as the ones on the turbo driveshafts?
Also how can I make sure the Turbo gearbox has the lsd fitted without splitting the casing? Is there anyway you can tell just with the gearbox on the bench? I know not all the gearboxes have the lsd fitted so how do i know if the on I have does?
Thanks
Bob
Happy New Year to everyone on PF.
Old Dec 29, 2006 | 10:35 PM
Ginge !'s Avatar
Ginge !
just finding my feet
look in the hole,,,, if theres a bar running across its NOT a lsd,,,,, you should be able to look straight though the driveshaft holes with no diagnol bar
also the xr2 mk2 box DOES fit,,,,,,, as my mates fitted 6 of em to his so far
Old Dec 29, 2006 | 11:08 PM
Rolls's Avatar
Rolls
seconded what the ginger one has said....
Old Dec 29, 2006 | 11:18 PM
XRT_si's Avatar
XRT_si
thats actually only 5
Old Dec 29, 2006 | 11:38 PM
Ginge !'s Avatar
Ginge !
sure that the one in your car now is number 6
ok then,,,,, 5 since you owned it,,,, which is less than engines
"its standard officer "
Old Dec 29, 2006 | 11:54 PM
TwoCossieBob
Default XR2
Thanks Guys
Once gain the PF board helps out.
Worth every penny of the membership on its own
Regards
Bob
Old Dec 29, 2006 | 11:57 PM
Ginge !'s Avatar
Ginge !
dont have to be a memeber for advice,,,, though i must remember to pay stu next time im up to see him
SmudgerByName
52
Jul 28, 2016 06:14 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Vacuman
16
Sep 3, 2015 06:26 AM
mint_s2
Sep 2, 2015 08:58 AM
Ben26
Aug 27, 2015 08:56 PM
