L8 ecu andp8 ecu how to tell them apart
Old Dec 29, 2006 | 07:12 PM
abdr500's Avatar
abdr500
Default L8 ecu andp8 ecu how to tell them apart
L8 ecu and p8 ecu how to tell the,m apart also what way could you tell if ther is a correct pectel bord in there as my one says pectel and has 2 chips that say cpv2 on 1 chip cpv2 on chip 2 and 3 other location for chips
Old Dec 29, 2006 | 07:19 PM
Alvyn's Avatar
Alvyn
standard L8 has a co screw P8 doesn't!
Old Dec 29, 2006 | 07:25 PM
Disabled Account's Avatar
Disabled Account
Here is a pic of an L8 ECU with baby board lifted off..............notice the mixture pot (top right):
Old Dec 29, 2006 | 07:26 PM
abdr500's Avatar
abdr500
Alvyn 1 question down 1 to go
Old Dec 29, 2006 | 07:28 PM
abdr500's Avatar
abdr500
Doug Stirling
ok thank you would of liked to see the bord to see if mine is correct to run as i want to use 750cc injectors ect ect
Old Dec 29, 2006 | 07:29 PM
Disabled Account
Not got a pic of a P8.........but here is a P8 baby board (Pectal):
Old Dec 29, 2006 | 07:35 PM
abdr500's Avatar
abdr500
Doug Stirling
thanks m8 my bord has the larger chips like the first chip you have but 2 more below it like the pic above 3 big chips in a row and on the sides i have 2 small ones like yours but on the side with cpv2 on them any idea
Old Dec 29, 2006 | 08:23 PM
abdr500's Avatar
abdr500
up for more info on the pectel borad
Old Dec 29, 2006 | 09:46 PM
davidreader5's Avatar
davidreader5
Hi,
Some early p8 ecu's had co% screw fitted.
Regards Dave R.
Old Dec 29, 2006 | 10:17 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
As said by David Reader above (Senna) The Early P8 ECU DID have a CO adjuster screw although it does not work.
The easy way to tell is by looking at the mother board.
A L8 comes with baby board
A P8 does not and also will not have the plug for it.
Regards
Old Dec 29, 2006 | 10:22 PM
abdr500's Avatar
abdr500
thanks to all for the info
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
