DTA Management Question
Old Dec 29, 2006 | 12:31 PM
Scott-rs2k's Avatar
Scott-rs2k
Default DTA Management Question
i hope to wire the dta management - loom in tommorow to the project car etc
i know where all goes but one - would anyone be able to tell me which wire on the ford loom i would connect the "dashboard" wire on the dta loom too.
I have asked on the DTA site and had no responce.
cheers peeps
Old Dec 29, 2006 | 12:33 PM
GARETH T's Avatar
GARETH T
whats the dashboard wire do?
Old Dec 29, 2006 | 12:37 PM
Scott-rs2k's Avatar
Scott-rs2k
to my knowledge ( i may be wrong) this wire wont stop it running its a wire that would i believe tell the management what revs or something the cars at - its probably used for mapping purposes. As i have a wire i run from the ecu to a laptop in the car and i can see real time everything etc i believe its something to do with that.
Old Dec 29, 2006 | 12:53 PM
NUTS RuS's Avatar
NUTS RuS
Which ECU do you have ?
Old Dec 29, 2006 | 12:54 PM
GARETH T's Avatar
GARETH T
like a CAN wire or a serial output,,,, my guessing is you wont be using it in your car
Old Dec 29, 2006 | 01:06 PM
Scott-rs2k's Avatar
Scott-rs2k
dta e48 ?
Old Dec 29, 2006 | 01:47 PM
NUTS RuS's Avatar
NUTS RuS
Only 2 wires go to the "dashboard" off an E48
The shiftlight and the rev counter
Do you already have these wired up ?
Old Dec 29, 2006 | 01:58 PM
Scott-rs2k's Avatar
Scott-rs2k
its not wired up yet mate will be tommorow - my guess it being the revs
so need to know which wire it is on the ford loom if you know mate
Old Dec 29, 2006 | 02:01 PM
NUTS RuS's Avatar
NUTS RuS
What coil pack are you using ?
There is a 3 or 4 pin plug that plugs into most,
Who did your wiring loom ?
mk3ste
Oct 17, 2021 10:09 AM
tankybaby66
Feb 6, 2016 02:24 PM
griffo69
Oct 4, 2015 11:58 AM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
deathrider666
Sep 28, 2015 06:12 PM
