2wd/4wd engine loom
Hi,
I think :
connection for TPS is diff. (inverted)
connection for dash indicator temp is different (front and rear of head)
connection for knock sensor (no exist on 2wd)
Regards
Claude
I think :
Regards
Claude
Originally Posted by cozmeister
To use an L8 loom with an L6 ECU you need to get a PF09 TPS and swap the outer two wires on the TPS connector.
To use a 4wd/L8 loom with a L6 ECU you would need to swap outer wires over on TPS plug,but still use the PF01(2WD) TPS
big_Rad
Sep 15, 2017 09:36 AM
muz
Aug 16, 2015 12:57 PM
