## Cossie chips /FAO STU##
Old Dec 28, 2006 | 11:54 AM
Csm's Avatar
Csm
Default ## Cossie chips /FAO STU##
If a chip has a turbo type on the wee sticker on top does that mean its only mapped for that specific turbo ???
Or can it be fitted and as long as the car is set up on the rollers it will be fine ??
Car is stage 3 ,turbo is T35 and sticker on chip says T34
Any info would be appreciated incase ive boobed
Thanks
Old Dec 28, 2006 | 12:06 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
Best not have damaged the car!!!
Old Dec 28, 2006 | 12:46 PM
SapphyMike's Avatar
SapphyMike
likely your turbo will be a T34
The DIVA's Avatar
The DIVA
Same thing in this case fella......
It ran on my car for 2000 miles without a prob so should be ok....
My Turbo is T35(Big turbo escos)some people call them T34 but there is no such thing.....
Old Dec 28, 2006 | 01:50 PM
Csm's Avatar
Csm
NO NO NO i know my turbo is a T35 as i repalced the fooker from a fooked T34
Its the chip that im changing as mine is faulty and i have bought a second hand ahmed bayjoo chip that has a wee sticker saying the tune accessories etc
tis cool it will be fitted and checked over at AVA next year if i havent sold the car
Old Dec 28, 2006 | 01:55 PM
NEIL A's Avatar
NEIL A
If you have went from a T34 with the .63 housing to a turbo technics T35 they have a .55 housing so will be slightly over fueling i guess.
Old Dec 28, 2006 | 01:57 PM
Csm's Avatar
Csm
Yeah when i bought the turbo ,Turbotechnics said it was just the New T34 basically
Old Dec 28, 2006 | 02:00 PM
NEIL A's Avatar
NEIL A
im sure turbo technics called there t34's with a .55 housing a T35 thats what i switched to when my old t34 went.
Old Dec 28, 2006 | 02:01 PM
Csm's Avatar
Csm
55 housing thats it , yep thats what i bought of em
Old Dec 28, 2006 | 02:10 PM
NEIL A's Avatar
NEIL A
well in that case the fueling will be slightly out at points of the rev range, but best wait for Stu or one of the other tuners to give you an exact answer.
Old Dec 28, 2006 | 09:24 PM
DazC's Avatar
DazC
The turbo is still a T03/4B (T34) whatever TurboTechnics want to call it. A T34 with a .55 housing is a downgraded T34 and a T34 with a .48 housing is downgrade further.
All depends what spec turbo the chip was wrote for but I would probably guess it was for the .63 rear end. If so, there will be more safety margin in using a chip for a bigger housing on a car with a smaller housing.
Forgot to mention, a real T35 is actually a diesel turbo for a DAF truck. It wouldn't survive the heat from a petrol engine if used hard.
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
