2WD Crank Pulley can it be welded ?????
Old Dec 27, 2006 | 02:45 PM
Alan s1's Avatar
Alan s1
Default 2WD Crank Pulley can it be welded ?????
Hi as above i broke my 2WD Crank Pulley and im having trobles getting on can it be welded ?????
Old Dec 27, 2006 | 02:54 PM
jon@work's Avatar
jon@work
could be a good buy if you can pick it up and save the postage...
http://cgi.ebay.co.uk/Sierra-RS500-3...em270072890236
Old Dec 27, 2006 | 03:20 PM
Jay,'s Avatar
Jay,
Sponsor
thats the goin rate to alan u tight git
Old Dec 27, 2006 | 03:22 PM
scruffythefirst's Avatar
scruffythefirst
They are cast Iron and need specialist welding. Then you need to re-balance it.
Old Dec 27, 2006 | 03:25 PM
PaulCossie's Avatar
PaulCossie
yes they can easily be welded and ground or machined back. I've done a couple for people.
the other option is a machined peg, drill and tap a small hole where the lug was and screw in a new one then machine it square.
not rocket science, just needs to be 4mm high and 4mm x 4mm square ( and conductive ( to trigger the sensor).
Old Dec 27, 2006 | 03:28 PM
PaulCossie's Avatar
PaulCossie
well i've welded a couple and they've worked fine
Old Dec 27, 2006 | 04:03 PM
Alan s1's Avatar
Alan s1
Its not the lug thats broke its chunk where when i was using the pullers it broke
Have one coming hopefully
Old Dec 27, 2006 | 04:04 PM
Alan s1's Avatar
Alan s1
I did'nt see that last night i have been looking since last wk
Someone has just PM me that has one so hopefully be getting that waiting on a reply
Old Dec 27, 2006 | 04:08 PM
Alan s1's Avatar
Alan s1
Its not that i have had no joy getting one since i broke mine and now i find 2 with in 20mins
Fingers crossed i'll have one by next wk
Ps Jay i have'nt got in the shed to sort that dash yet been very busy (the engine and box in the cossie is only being held in via the gear box craidle and i have the crane ready in the big shed next whk it should be out )
Old Dec 27, 2006 | 04:35 PM
Neil S's Avatar
Neil S
My mate broke mine 3 years ago, I had it welded and it's been fine since
Neil.
Old Dec 27, 2006 | 04:37 PM
Alan s1's Avatar
Alan s1
Neil.
May get it done for a spare
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
155lee
Oct 27, 2015 04:55 AM
mark r
Sep 29, 2015 07:27 PM
Russ Payne
Sep 25, 2015 08:29 PM
