Which is better 2wd or 4x4 exhaust manifold
Old Dec 27, 2006 | 12:40 PM
Twellsie's Avatar
Twellsie
Default Which is better 2wd or 4x4 exhaust manifold
as above, and are they just a straight forward swap?
Old Dec 29, 2006 | 12:05 PM
dox's Avatar
dox
2wd manifold produces more tourqe then the 4wd manifold, i run a 2wd one on my 4x4
yup straight swap but u wll need a turbo dampner/hanger thingee.
Old Dec 29, 2006 | 12:25 PM
KSA-Cossie's Avatar
KSA-Cossie
Don't you need to rotate the housing too ?
Old Dec 29, 2006 | 12:33 PM
costina's Avatar
costina
Live long and prosper!!
thought it was the other way round (like havin a smaller bore exhaust)
2wd is a better flowing and makes more power!!!!!
Old Dec 29, 2006 | 12:56 PM
Twellsie's Avatar
Twellsie
the thing that mounts off the top of the cam cover?
what do standard 2wd's use?
Old Dec 29, 2006 | 01:02 PM
dakar's Avatar
dakar
there is a bailey turbo damper for sale in the for sale section if it helps mate there a good bit of kit
Old Dec 29, 2006 | 02:20 PM
dazzle740's Avatar
dazzle740
you can swap 2wd manifold for the 4x4 or vice vesa but you will need to rotate the compressor housing of your turbo and get a turbo damper
i presume you are going from 4x4 to 2wd
if so what spec is your engine
Old Dec 29, 2006 | 02:48 PM
Twellsie's Avatar
Twellsie
yeah 4x4 to 2wd, was just thinking if there would be any benifit as i have got the head off and 2wd manifolds seem cheap enough
as for spec at the moment its on greys, T3, Magnex exhaust, the head is going away shortly to be flowed, and i am going to fab a bigger intercooler when i can be arsed and when i have decided how big
Old Dec 29, 2006 | 03:12 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
4x4 manifolds are better up until 450bhp, then the 2wd one is better
Old Dec 29, 2006 | 03:16 PM
Twellsie's Avatar
Twellsie
well i am not palnning to take the power up anywhere near that high, might just stick with what ive got?
Old Dec 29, 2006 | 03:20 PM
NUTTIN RILLA
what does your car run like with the greys, seen as you still have a t3 and standard cooler i cant see you running big boost so im wondering why you have greys and not just a set of greens, is it lumpy in the morning? how bad is it on fuel?
Old Dec 29, 2006 | 03:25 PM
Twellsie's Avatar
Twellsie
it runs at 1.7 bar, ran sweet as a nut, only used Greys as i had some at the time and will be changing the turbo in the future
Old Dec 29, 2006 | 03:28 PM
NUTTIN RILLA
Good stuff mate
Old Dec 29, 2006 | 06:18 PM
mike72168's Avatar
mike72168
I was told the turbo sits slightly higher on a 2wd exhaust manifold than on a 4wd exhaust manifold which would effect exhaust height and the plumbing for the oil and water pipework,can anyone else confirm this?
Old Dec 29, 2006 | 06:30 PM
crash_ash's Avatar
crash_ash
2wd manifold made the downpipe foul on my front prop and chassis rail
Old Dec 29, 2006 | 06:33 PM
mike72168's Avatar
mike72168
So did your downpipe sit higher with a 4wd xhaust manifold?
Old Dec 29, 2006 | 07:20 PM
jon@work's Avatar
jon@work
turbo sits slightly higher on a 4x4 manifold than with the 2wd manifold
May 31, 2016 09:28 PM
frug
Aug 26, 2015 06:46 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 20, 2015 07:45 AM
IAN RS2k
Aug 18, 2015 07:51 PM
Aug 14, 2015 07:29 AM
