Saff bottom end rebuild advice please.
Old Dec 26, 2006 | 10:44 AM
adam rs's Avatar
adam rs
Default Saff bottom end rebuild advice please.
Hi! i have decided im going to rebuild the engine in my 4x4 sapphire early in the new year and need some advice on compression ratios.Eventually as money permits i would like to be running a reliable 400 to 450bhp so the rebuild will obviously be done with this in mind.Do i really need to go low compression? if so what would be the right ratio to go for?All input greatly recived as i have only had the car 6 months so all this is abit new to me! and before anyone tells me i do realise the standard gearbox wont take this and am thinking about a rayland straight cut fix it kit.Thanks.
Old Dec 26, 2006 | 01:50 PM
DAN P's Avatar
DAN P
781 t38 ported head cams will see you 400 to 430 m8 and speak to marco about a gear box m8
KW-rscos
11
Aug 31, 2015 01:51 PM
mrknifey
Aug 30, 2015 11:48 AM
IAN RS2k
Aug 18, 2015 07:51 PM
john_3.0s
Aug 15, 2015 07:44 AM
knight19770
Aug 4, 2015 12:36 PM
