mis-firing RS500!
Hello all, wonder if anyone can help me, when I really floor the RS500 I am getting a mis-fire, but if I gradually build it up it is fine. I have been told it may be the fuel pump, does this sound about right?
The spec is :
New RS500 block/engine
live mapped
green injectors etc...
It runs fine apart from that!
Thanks
Lee
The spec is :
live mapped
Thanks
Lee
Took it out today, and seems a bit better, but have decided I am going to change the phase sensor and see what that does....
Then it may be a new fule pump
Still, goes VERY well mind you!!!
Lee
Lee
Originally Posted by costina
boost spiking to high see what it is at both flooring and gradually
regap plugs to .6 mm and tweek the boost down
My standard actuator has nearly no pre-load at all on it though
I put a -31 on it and a chip and it was peaking at 1.2 bar with 1/2 a hole pre-load. I didn't test it properly because saw 1.2 bar and backed off before seeing if it settled
I removed the -31 before I caused any damage but when I put it back to standard I noticed that the standard one is spiking like this and it got me wondering
I might put the -31 back on tomorrow and give it all another go
the only thing you can do will the amal valve is change the plastic sleeves in the pipe's for different size ones to lower and increasae boost as to much preload on a actuator is not good for the turbo this is how i increase boost pressures via the amal valve not the actuator the amal valve shold click when there is a 12v supply put to it
you cant take them apart mate just look inside the three pipes that are on there iside them will be little white sleeves use a screw in the end of the to with draw them. think they might be but i normally get them from bluesprint in essex. check that the amal valve is working as well mate turn the igniton on and pull the plug off of the amal valve it should click if its working if it dont get a new one
Originally Posted by paulpalmer
Thanks
I'm sure it's working but I'm wondering if someone has been messing with the sleeves in the past. I'll take a look.
I'm sure it's working but I'm wondering if someone has been messing with the sleeves in the past. I'll take a look.its not the coil just a boost spike blowing spark out !!!! re-gap the plugs .6mm
It should hold 1 bar and spike a little higher
Thanks
Originally Posted by MARCOSWORTH
What should the plug (agps071c) gap be then for a stage 3 set up?
Standard or smaller?
its just a case of trial and error depending on your ign system..
Thanks
They are now gapped to .6mm
Thanks
