buying a used focus
Old Dec 22, 2006 | 11:24 AM
pedro_de_la_cruz's Avatar
pedro_de_la_cruz
Default buying a used focus
right guys ive found a 1.6 focus on a 01 plate and its £4000
im going to view it later on today so really want to know what sort of faults to look out for specific to the focus if there are any i should look out for
any advice is greatly appreciated
i just signed up to the forum today so hi everyone!
Old Dec 22, 2006 | 07:07 PM
zippy144's Avatar
zippy144
Hi
Oversly look for all the usual things, like accident damage, cut and shut etc.
Most Focus's suffer from rust either under the wing mirrors or under the trim on the tailgate.
When you drive it listen out for the wheel bearings as they are quite common to fail...
Good Luck
Regards
Tom aka Zippy
Old Dec 23, 2006 | 11:17 AM
RichieST's Avatar
RichieST
more usual things like headlights misting up, rust around the aerial base, make sure the plastic scuttle panel trim is firmly sealed to the windscreen, if not water will seep through there, and into the passenger footwell soaking the carpet.
These 1.6s do have the tendancy to burn oil too, i sold my 1.6 focus just before it was needing its third engine!!!!
Old Dec 23, 2006 | 01:22 PM
Focus-Pocus Estate's Avatar
Focus-Pocus Estate
good site for advice.......
http://www.honestjohn.co.uk/index.ph...ycar/index.htm
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
gavt123
Sep 5, 2015 10:03 AM
Ben26
Sep 3, 2015 07:55 PM
Sep 3, 2015 10:49 AM
