help with s2 rs turbo please
Old Dec 20, 2006 | 03:39 PM
reded06RS's Avatar
reded06RS
Default help with s2 rs turbo please
i have just purchached a 1990 spec rs escort the person had fitted a big actuater and not set it up so i sent it in to camco and he has set it at 12psi but in 4th and 5th gear it over boosts still 1st 2nd and 3rd fine does this mean i need a chip for this as i was told it was chipped but unknown no proof if this please can anybody help
Old Dec 20, 2006 | 03:57 PM
davsmith64's Avatar
davsmith64
sounds to be overboosting to me mate, better off taking the actuator rod off of the wastegate, screw it out 1/2 turns at a time and testing it, i.e. lenthen the rod.
at around 8-10psi it shouldnt overboost
Old Dec 20, 2006 | 04:23 PM
reded06RS's Avatar
reded06RS
camco said the actuater wont go less than 12 psi would i be better just getting it chipped to take that and would the engine last or wat other mods would i need and wat chip u recomend
Old Dec 20, 2006 | 04:59 PM
gup's Avatar
gup
try unplugging the amal valve for a bit till you get a dash 31 or a chipped ecu
Hrsturbo's Avatar
Hrsturbo
any chip will do and get it set up at 15psi once fitted
Old Dec 20, 2006 | 05:03 PM
reded06RS's Avatar
reded06RS
15 psi on standerd moter with no other mods?
Old Dec 20, 2006 | 05:08 PM
reded06RS's Avatar
reded06RS
and if i get a chipped ecu can i just plug it in or do u have to get anythink else done
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
