What is the correct ET for a S2
I have searched the forum but cannot find anything om the standard ET for the S2.
Could someone tell me what it is ?
And should i change the ET if i go for a set of 17" and a big brake kit like Hispec 300mm 4 pot ??
Henrik
Henrik
"The offset is described by the term ET, which is from the German word 'Einpresstiefe' translated as 'insertion depth'." Measured in millimeters.
I always thought it was ET35 on an RS turbo...
Thanks
But if i was to buy some 17" Team Dynamics Pro Race 1 with ET36.5 would there be enough space betwen the rim and a big brake kit from Hispec or Tarox ??
I wouldnt buy any brakes off Low Spec,either they wont fit,or you'll never get them till months after the supposed delivery date.Do a search on here and see all the negative posts about them.Regards,Micky
THIS SHOULD HELP MATE
Model
Year PCD
Offset
Bore
Cougar
98 to 02
4x108
35 to 45
63.4
Escort / Orion
80 to 90
4x108
35 to 38
63.4
Escort Cosworth
92 to 96
4x108
15 to 20
63.4
Fiesta
90 to 01
4x108
35 to 38
63.4
New Fiesta after 02 4x108 35 to 45 63.4
Focus after 98 4x108 38 to 49 63.4
Focus C-MAX after 03 5x108 37 to 38 63.4
Focus RS after 03 4x108 40 to 45 63.4
Fusion after 02 4x108 37 to 45 63.4
Galaxy after 95 5x112 35 to 45 57.1
KA after 96 4x108 35 to 38 63.4
Maverick 93 to 96 -- 35 to 45 --
Mondeo 93 to 00 4x108 35 to 38 63.4
New Mondeo after 00 5x108 35 to 45 63.4
Probe 94 to 98 5x114 35 to 38 67.1
Puma up to 01 4x108 35 to 38 63.4
Scorpio 94 to 00 4x108 35 to 38 63.4
Scorpio / Granada 86 to 94 5x112 35 to 38 63.4
Sierra & Cosworth 84 to 94 4x108 35 to 45 63.4
Street KA after 03 4x108 38 63.4
Transit Connect after 02 5x108 35 to 45 63.4
Model
Year PCD
Offset
Bore
Cougar
98 to 02
4x108
35 to 45
63.4
Escort / Orion
80 to 90
4x108
35 to 38
63.4
Escort Cosworth
92 to 96
4x108
15 to 20
63.4
Fiesta
90 to 01
4x108
35 to 38
63.4
There is no "correct" offset once you start going to bigger rims.
The recommended offsets are Et35 - ET45. Depending on how low you are, whether you arches are ground/rolled, choice of tyres etc, will all affect what offset you can use successfully.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
OrionRST200bhp
Sep 29, 2015 08:30 PM
