tight gears
what would cause the gears to go tight after ive been driving for a while only happens if im starting and stopping alot when driving around the town, its ok on long journeys ? the clutch bites about 20mm off the floor if thats anything to do with it ? or is that the sign of the gearbox on its way out cheers in advance
i had this afew years back gears were fine when cold then would go real tight got that pissed off in the end had the gearbox stripped. Box was found to be in good nick but the oil was like treacle really thick as probably had never been drained due to no drain plug.Replaced the bearings as a precaution and has never given grief since.Maybe this is your problem mate hope this helps.
Pop out a driveshaft to drain, refit shaft, then refill by undoing the plug at the front. Just refill on level ground until the oil starts weeping out (about 4.2l )
safechav
i think its time for the turbo cab to come out to play
i heard it was superduper spec
safechav spec head 38 mm inlet ports
safechav spec cam 15mm lift 400 deg duration
safechav superduper injection system secret spec
gt30 turbo
40 psi boost
gt30 turbo
40 psi boost
The Youth.
Sep 30, 2015 09:59 PM
