size of rear driveshaft nut on cossie?
Old Dec 16, 2006 | 04:13 PM
banhambuilt's Avatar
banhambuilt
Default size of rear driveshaft nut on cossie?
as above really,cossie 4x4 drive shaft outer nut (front and rear)size please.
is there a good place to get a socket from?
cheers
dave
Old Dec 16, 2006 | 06:00 PM
Sideways_Sierra's Avatar
Sideways_Sierra
This the one you see when you take one of the rear wheels off ?
About a 36 or 40 or summin I think, quite big
Old Dec 17, 2006 | 10:05 AM
2001ode's Avatar
2001ode
Hi,
On 2wd rear nut, it is 41 mm. socket, sure.
(dont forget : right thread on right side / left thread on left side)
Regards.
Claude
Old Dec 17, 2006 | 10:12 AM
cossie604's Avatar
cossie604
As above...41mm for the rears. You can buy a cheapy for around a tenner..the one I bought was actually labeled as a Sierra rear hub nut socket
Stu.
Old Mar 22, 2013 | 06:03 PM
colly cosie's Avatar
colly cosie
Would any one no the spec of the 41mm nut off the shaft example m10x 15? As i need to get one but have no spec and ford dont have them on the shelf need to sorce on asap.
Old Mar 22, 2013 | 09:20 PM
Sonic Boom's Avatar
Sonic Boom
They are M20 x 1.5 mate, you can buy them off ebay for around a tenner.
Rich
Old Mar 22, 2013 | 09:21 PM
Sonic Boom's Avatar
Sonic Boom
O/S (Green)
http://www.ebay.co.uk/itm/ford-sierr...item41652b7733
N/S (White)
http://www.ebay.co.uk/itm/ford-sierr...item41652b6f62
Rich
Old Mar 22, 2013 | 09:26 PM
fraser9764's Avatar
fraser9764
I see you are in crewe, If you need one this weekend, warnhill tool and fasteners in winsford should have one. They are open till 1 I think tomorrow. Tell them Graham with the cossie sent you, they should do you a decent price, probably be more than ebay though.
Old Mar 22, 2013 | 10:25 PM
colly cosie
Thanks alot lads great help. Cheers.
Im looking a set off escort cosworth wheels but im in the ni and dont fancy payin 550 for a set any one no were I could get a good set?
Oct 9, 2015 07:38 PM
rst-s1
Aug 23, 2015 07:56 AM
borboyous
Aug 22, 2015 11:17 AM
Bosch
Aug 4, 2015 05:14 PM
