over heating turbo
Old Dec 16, 2006 | 11:17 AM
Zetecfiesta's Avatar
Zetecfiesta
Default over heating turbo
ive fitted my front mount and now the other day the car got really hot and it over heated and it kinda pissed out some coolent from the left hand side probably header tank, anything i can do to stop it doing that again? i dont think i chould have tried racing my mate in an evo though!
Old Dec 16, 2006 | 12:12 PM
Tombra's Avatar
Tombra
what fan setup are you running?
With a full size IC you need to run twin fans.
Old Dec 16, 2006 | 12:24 PM
addiction's Avatar
addiction
twin fans mounted on the radiator
82 degree thermostat
saph cos fan sender
with all these fitted you should have no overheating problems
Old Dec 16, 2006 | 01:02 PM
SafeChav's Avatar
SafeChav
Put the fan on a bypass switch aswell! An essential mod IMO.
Old Dec 16, 2006 | 04:15 PM
Zetecfiesta
ahhh ive only got 1 fan but i do have a 82 degree thermostat, where do i get a saph cos fan sender from and another fan? lol
Old Dec 16, 2006 | 04:28 PM
SafeChav's Avatar
SafeChav
Just put a fan over-ride in mate, you can have the fan on constantly then if you like, and it will still cut in at the normal temperature!
Get twin fans, wire an override, and i reckon you will be ok
Old Dec 16, 2006 | 04:38 PM
Tombra's Avatar
Tombra
twin fans will do the trick.
I tryed mine with just one fan, it overheated like fook
now running 2 10" fans and GRS IC, no problems at all
2 10" fans are a tight fit on the std radiator, but with some trimming it will fit.
Good luck
Old Dec 16, 2006 | 05:16 PM
jimmylaud's Avatar
jimmylaud
how do you do the bypass safe chav cheers
Old Dec 16, 2006 | 06:15 PM
jimmylaud's Avatar
jimmylaud
SafeChav
how do you do that bypass switch bud
Old Dec 16, 2006 | 08:20 PM
SafeChav's Avatar
SafeChav
If this diagram makes sense to you, then this is how
Old Dec 16, 2006 | 11:40 PM
jimmylaud's Avatar
jimmylaud
perfect cheers for that safe chav
Old Dec 17, 2006 | 12:47 PM
Zetecfiesta
thanks!
Old Dec 17, 2006 | 03:44 PM
SafeChav's Avatar
SafeChav
No worries.
The LED is optional, but a good addition IMO. It will also tell you when the fan is running from the fan switch aswell
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
kevin36
Sep 2, 2015 06:24 PM
