Slight misfire
My 2 wheel drive sapphire has a slight misfire
I start it from cold and it's like it's flooded on 1 cylinder because after a rev it clears. As you drive along sometimes it seems to misfire on boost like a flatspot
It's hard to describe but it then clears and off you go. The car generally runs sweet apart from this misfire/flatspot
I've changed the spark plugs, leads, rotor arm & distributor cap but it's not made a difference.
What might it be?
Thanks
What might it be?
Thanks
It's got no other head gasket symptoms and doesn't use water
Yet
It's all good apart from a very very minor misfire. The car is very quick, holds temperature etc
I'm probably worrying over nothing. I have got to change the fuel filter though but I'm sure that's not harming it.
The Enigma
Sep 12, 2015 10:12 PM
