puma gear linkage conversion....
Old Dec 14, 2006 | 07:39 PM
RST_mark's Avatar
RST_mark
Default puma gear linkage conversion....
Hi, was hoping someone can help me on this. Drove a puma today and noticed the gear selection was really positive and close. Am sure i've heard before that these can be used on s2 rs's.
Is this right and what do i need to get and do to make it all work?
Maybe Jano might be able to help on this one......?
Cheers, Mark
Old Dec 15, 2006 | 06:17 PM
RST_mark's Avatar
RST_mark
someone must have some info on this.......
Old Dec 15, 2006 | 07:47 PM
Rick's Avatar
Rick
they do have a nice change
Old Dec 15, 2006 | 11:27 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Old Dec 17, 2006 | 07:02 AM
JesseT's Avatar
JesseT
Just buy one and install it. The small things to be taken care of you will notice when you install it. There are two things to consider if I recall. The mounting of the shifter to the body is different and the length of the rods possibly needed shortening.
Old Dec 19, 2006 | 07:58 PM
RST_mark's Avatar
RST_mark
I don't mind having a go, just thought i would research it before i go out looking for one.
Surely someone has done this conversion and can help me
Old Dec 21, 2006 | 07:28 PM
JesseT's Avatar
JesseT
Recently spoke to a friend who has one fitted to his S2. He said the gearbox end is p'n'p. The selector itself sits a bit further back than the original one and can be left that way (he did), but ~1-2cm can be taken away from the selector rods if one wants the stick to sit exactly where it was. Then the plastic casing of the selector box is a bit wide to comfortably sit in the S1/S2 chassis tunnel and a little grinding was needed. The fixing to the body is different and can be done with the Puma's bracket or any other way one sees fit. The selector itself is quite cheep, cheeper than overhauling the old one. It's around 100e here at Fords, so around 60-70Ł over there on the rainy island.
Old Dec 21, 2006 | 07:30 PM
Versus_Creations
Ask me a question!
Originally Posted by JesseT
rainy island.
Old Dec 21, 2006 | 07:31 PM
JesseT's Avatar
JesseT
That was one fast raply. Do you always keep guard here?
Old Dec 21, 2006 | 07:36 PM
Rick's Avatar
Rick
So as is, the puma sits the stick further back? How does effect the interior console/gator? A little further back would be quite good for tall people like me
Versus_Creations
Ask me a question!
Im always in the tech sections
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
The Youth.
Sep 30, 2015 09:59 PM
youngben
Sep 27, 2015 09:37 PM
Marv888
Sep 26, 2015 03:44 PM
