cossie clocks
How many different types of speedo clocks are available for sierra cosworths.
My car still has the original clocks fitted, and I want to keep them and I am trying to look for a replacement set of clocks to tinker with.
So far I have seen clocks with a boost gauge in the corner? – RS500?
I have seen ones with number son the fuel tank markings.
I found a set that look identical to mine…..but have no redline, on the dial faces
Are all the clocks the same, ie same type of rev counter etc?
As I am looking for a set to go into my late spec 4x4 saff, that I can try out a new set of dial faces etc
Any help with whats what??
Rev counters have a C marked on them and the 170 mph,as for the fuel and temp they can differ but all are ok
on the c rec counter the red area is 6.5 k on others there 6
hope the helps a bit
the 500 clocks will fit but will require a lot of wiring changes and a possible tank sender change
Mr S1
20
Sep 27, 2015 04:06 PM
