Engine differencees on escos weber / eec-iv???
Old Dec 13, 2006 | 08:22 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
Default Engine differencees on escos weber / eec-iv???
What is the main differences?
I know about the coil and management, but what else?
The oilpump is a lot cheeper? why?
Anything else?
Old Dec 13, 2006 | 08:23 PM
rapidcossie's Avatar
rapidcossie
block has better oil squirts...on eecv
Old Dec 13, 2006 | 08:31 PM
cossiemanden
I asume that this is the inserts from the oilpump?
What are the differences in the oilpumps???
Old Dec 13, 2006 | 08:35 PM
rapidcossie
the oil squirts spray onto the bottom of the pistons to keep them cool..essential at high boost/high RPM
have no idea about the pumps mate?
i think the eecv block is slighty stronger thana regular 200 block too fue to smaller core plugs? could be wrong tho.
Old Dec 13, 2006 | 08:56 PM
cossiemanden
Isen`t the std escos 93 spray ones good enough???
The block i have heard of, but not sure either
Old Dec 14, 2006 | 11:44 AM
YBP's Avatar
YBP
I run an YBP engine.
The YBP block uses oiljets mounted directly onto the block and because of this a regular pinto oilpump can be used. Or in my case I used an uprated high capacity/high pressure pump. This will fit with a little modification. Still alot cheaper than a regular cosworth oilpump.
The last t25 engines has m6 bolts on the cam bearing caps and are not suited for uprated valvesprings and/or wild cams.
It has bigger waterchannels in the head so not ideal for your 700+bhp enginebuild because the port size is limited by this. Not a real problem on a more "normal" 5-600bhp engine tho.
It also has new and stronger flushmounted valveguides to improve flow.
Bigger plenum elbow and throttlebody to.
Old Dec 14, 2006 | 01:22 PM
the original's Avatar
the original
I think windage tray fitted to eec4 but not p8 models?
Old Dec 14, 2006 | 01:40 PM
Paul_RS's Avatar
Paul_RS
What exactly does a windage tray do?
Old Dec 14, 2006 | 01:44 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Stops the crank from picking up all the oil in the sump and throwing it everywhere at high rpm.....
Old Dec 14, 2006 | 02:19 PM
Paul_RS's Avatar
Paul_RS
Ahh right, thanks Mike
Old Dec 14, 2006 | 03:30 PM
YBP's Avatar
YBP
It´s also pretty thick and stiff.
I had to modify it to make the bigger oilpump fit, and found it very hard to cut into. So I believe it serves a purpose as a "girder light" supporting the main caps a little.
james kiely
Aug 28, 2015 08:58 PM
costina
18
Aug 25, 2015 06:02 PM
c20tbo
Aug 17, 2015 10:19 PM
muz
Aug 16, 2015 12:57 PM
markk
Aug 15, 2015 01:38 PM
