will any s2 rs turbo euc fit any s2 rs turbo??????????
Old Dec 13, 2006 | 06:16 PM
lawnsy's Avatar
lawnsy
Default will any s2 rs turbo euc fit any s2 rs turbo??????????
i have just been offered a chipped s2 rs turbo ecu for our lasses car but i can remember they have different symbols on them so do i need exactly the same one or will it plug and play.....
both cars are s2 rs turbo's
and also how can i check his is a s2 and not a s1 ecu????
Cheers john....
Old Dec 13, 2006 | 06:19 PM
Billabong's Avatar
Billabong
The ECU (silver box) should have a sticker with identifying features:
blue red blue is S1
the hearts etc is 90 spec S2
blue red black is 88 spec S2
blue red white is 86 spec S2
Old Dec 13, 2006 | 06:22 PM
lawnsy's Avatar
lawnsy
cheers so does anyone know if all the s2 ecu's will just plug and play or will it have to be the same markings??????
Old Dec 13, 2006 | 06:39 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
yes it they will physically fit.
No not all will work.
ones with knock sensor function will only work on cars with a knock sensor, ones without knock sensor function will work on any engine afaik!
Old Dec 13, 2006 | 07:04 PM
lawnsy's Avatar
lawnsy
mmmmmmmmm so realy i need to get it and try it..
Old Dec 13, 2006 | 07:52 PM
vroooom ptssssh
It Wasnt Me!
Easiest option is to go for:
Blue-Red-Blue = Series one cars (B, C, D)
Blue-Red-White = Early series two cars, with no knock sensor, mainly the first D plates
or if you have a knock sensor on your car and want to keep its function or can get these ECU's easier (remember they only work with knock senor equipped cars)
Blue-Red-Black = Series 2 cars with a knock sensor (E, F, G)
Hearts & Diamonds = 90 spec cars, with a knock sensor (G, H)
Old Dec 13, 2006 | 07:58 PM
lawnsy's Avatar
lawnsy
hot can i tell if her engine has got a knock sensor - were about is it...
car'nt go off year as it is a cabbie with a rs turbo convertion.....think ill have to have a look on her ecu..
Old Dec 13, 2006 | 08:20 PM
davidreader5's Avatar
davidreader5
Hi,
The knock sensor is on the right top side END of the inlet plenum(manifold)
as you look into the engine bay from memory it is a green sensor.
if you need any std ecu's i have some.
Dave R.
Old Dec 13, 2006 | 09:15 PM
lawnsy's Avatar
lawnsy
or is that what it is......yip it got one of them...
EoinXR3
Sep 7, 2015 05:44 AM
marky_g
Aug 15, 2015 10:43 AM
