Pink fuel relay test
To test the TPS the stick a continuity meter on it between two of the pins when the throttle is closed (think its the middle and bottom) you should get a circuit.
When you open the throttle fully it should break the circuit and link up the middle and top pins.
I had this problem at the begining of the week. 2 out of 3 were faulty.
Who told you that
ok, I discconect TPS, and put ohm meter betwen two pins, I dont remember but about few Ohm was reading. I push throttle, and still same reading. ???
question 2: when i mounting TPS must I hear "click" when I relase throttle fully??
ok. when I get contact by turning key, my pump make bzzzzz, is that mean pump relay is ok?
and here are one picture, for qouestion about throttle position sensor.
http://i115.photobucket.com/albums/n...0/RSTprobl.jpg
THANKS
THANKS
By the way..if you switch the ignition on & off quickly in succession, the pump will not prime continuously..there has to be a small time gap for it to re-prime. This is normal and is not a fault.
Shawn, a priming fuel pump relay doesnt mean its working fully, ive seen numerous relays that will do just one or the other.
Now.......your TPS. It has basically 2 switches inside. With the throttle fully closed (it should click as soon as the throttle is opened the smallest amount), you should get continuity across one switch.
Then hold the throttle fully open, there should be continuity across the other switch.
There should be no continuity between any pins if the throttle isnt fully open or fully closed.
THANKS
THANKS
rs shawn, basically yea.
To prime it needs 12v from the ignition. To run with the engine it has to see the LT from the coil.
Usually they stop priming, but will still run the car. Its not a massive problem when they do this but can make starting from cold difficult.
This is only really on the pink relays though, why oh why Ford reverted back to the pink ones from the Series 1 relay i will never work out
And im either blind, stupid, or that link doesnt say anything about testing relays.
nipper.1
Ford KUGA
12
May 30, 2022 07:39 PM
