2wd oil pressure at tick over?
Old Dec 13, 2006 | 12:14 PM
escort mk6's Avatar
escort mk6
Default 2wd oil pressure at tick over?
what pressure (bar) should the engine produce on tick over (started from cold) and what should it drop to when warm?
its a stg3 engine.
cheers all,
Old Dec 13, 2006 | 11:15 PM
escort mk6's Avatar
escort mk6
anyone?
Old Dec 14, 2006 | 07:13 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Mine is 55psi when cold on idle
About 34psi on hot idle
Steve.
Old Dec 14, 2006 | 07:22 AM
Jay,'s Avatar
Jay,
Sponsor
cosworth say 1.8 bar @ idle
Old Dec 14, 2006 | 08:03 AM
...depends on oil grade....
20psi to 35psi
The Ford oil pressure switch i beleive comes on at 15psi
Old Dec 14, 2006 | 09:24 AM
abdr500's Avatar
abdr500
from cold my one runs 5 bar till warm after this once warm it runs a constant 2.5 bar i have a uprated oil pump
Old Dec 14, 2006 | 09:29 AM
TiB's Avatar
TiB
It also depends greatly on where you have your tickover set...
Lee
Old Dec 14, 2006 | 12:46 PM
escort mk6's Avatar
escort mk6
tick over was 1400 on initial start, fell to 1100, showing 3.5 bar whislt cold, so all seems in order, i was just getting worried as the engine can get very loud sometimes, but ive since read that Castrol RS can make the engine loud?
what oil does everyone else use, as im off to buy some new now
dombanks
Sep 21, 2015 08:38 PM
3doorcozmess
Sep 15, 2015 06:06 PM
dojj
28
Sep 11, 2015 10:00 PM
rsstav
Sep 7, 2015 04:43 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
